Slot is empty or does not support clock participate
I initiallly configured 2600 cisco router. And than I installed WIC-2T card. It installed perfectly fine. But now when I amd trying to access the router using hyperterminal I get this error and I cannot go to the command line
"Slot is empty or does not support clock participate
WIC slot is empty or does not support clock participate"
Can someone help me why is that?
Moazzam
1 REPLY
Bronze
Re: Slot is empty or does not support clock participate
it seems that you are using a couple of CSU/DSU cards .This message indicates that you dont have the feature in your card:If your WIC interface does not use any network clock for timing tehn you can ignore this message
903
