SLOT0:ON SUP 1-2GE
Hi All!
PS;Have a look to these output when i try to format the PC CARD On slot0:
Console> (enable) format slot0:
All sectors will be erased, proceed (y/n) [n]? y
Enter volume id (up to 31 characters):
Unknown device mfg id (ffffffff.ffffffff.ffffffff)error = -1
Format device slot0 failed (unspecified error)Console> (enable) .
whai is "the Enter volume id"waht should i enter in this field?
10xs for ur help
Ali
  • WAN Routing and Switching
Re: SLOT0:ON SUP 1-2GE
Hello Ali,
for the volume id, just accept the default and press return, you do not need to enter anything there. Your problem might rather be related to the PC card not being recognized by the IOS, which could have several reasons, e.g. the card is damaged, or it is a third party card not compatible with the Supervisor. When you do a ' dir slot0:' do you see any files on the card ?
GNT
Hi Friend!
when i issue the Dir Slot0:i dont see any thing.but the Pc Card Is:Cisco system Brand.64-MB linear Flash PC card (MEM-C6K-FLC64M=)..B/W.The the 6509 RUN Catos & ios on the MSFC..
10XS
ALI
114
