Slow DNS lookups with Cisco 837
I've recently upgraded to a Cisco 837 ADSL router and it's working ok apart from one problem.
I run my own DNS server on my internal network and all PCs on my network use it for DNS lookups. It's a Windows Server 2003 box running the Microsoft DNS service.
Under my last router this worked fine, but with this router DNS lookups are horrendously slow, usually taking over 10 seconds to lookup a website.
When I set my PCs to use public external DNS servers (like 4.2.2.1 & 4.2.2.2) DNS lookups are reasonably normal speed, which indicates that it's a problem inside my network.
The DNS server has not been changed at a ll since changing routers, so I have no idea what the problem is.
Re: Slow DNS lookups with Cisco 837
Hello Mark,
can you post the configuration of your 837, and indicate what the IP address is of your internal DNS server ?
GNT
Thanks for the reply, here it is.
The DNS server is 192.168.1.3 and my PC is 192.168.1.5, and I'm using one-to-one NAT to translate the private addresses into my public /29 IP address range:
Current configuration : 1390 bytes
! Last configuration change at 00:00:03 UTC Sat Jul 22 2006
! NVRAM config last updated at 22:36:34 UTC Fri Jul 21 2006
version 12.2
no service pad
service password-encryption
hostname WAN-1
logging queue-limit 100
enable secret
ip subnet-zero
ip audit notify log
ip audit po max-events 100
no ftp-server write-enable
interface Ethernet0
ip nat inside
hold-queue 100 out
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
interface Dialer0
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication chap pap callin
ppp chap hostname
ppp chap password
ppp pap sent-username password
ip nat inside source static 192.168.1.3 87.127.54.19
ip nat inside source static 192.168.1.5 87.127.54.21
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
no ip http secure-server
line con 0
password
logging synchronous
login
no modem enable
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password
login
scheduler max-task-time 5000
end
I assume you need the DNS server to be accessible from the outside as well ? If so, try and add:
ip dns server 192.168.1.3
to your configuration. Also, make sure your client 192.168.1.5 has the address of the DNS server configured in the local TCP/IP connection settings (obvious, I guess...)
If there is no need for the DNS server to be accessible from the outside, just remove the line:
from your configuration alltogether.
GNT
Yes, I have configured the clients to use the DNS server. Also, the DNS server must be accessable from the internet as it also hosts a website.
I tried entering the command both in global configuration and in priviledged exec but it wouldn't let me, it came up with "invalid input detected".
Ok, I think that command was slightly different on this router, I used the "ip name-server 192.168.1.3" command and that worked, but DNS is still slow.
I have noticed the same thing with an 837 router - slow performance of the built-in DNS server. From a few hints I gleaned from packet traces, looked like it was not caching responses but passing them all to an authoritative DNS server. That would slow things down considerably...
Jonathan
Hi Jonathan,
Try making an entry to your DNS Server to look for a root server specified by you e.g 4.2.2.2.
You can make this entry in to the Win2k3 Server's DNS Config.
Hope it works,
Wilson Samuel
242
