Slow download
vishwancc
Level 3
Level 3
Hi ALL :
I am facing this problem for a some time now.
I have 4503 switch which is connected to PIx and my server.
I have few vlan on the switch ,so when i am intarvlan transfer of data no issue.
But when intervlan data transfer its very slow.
All the vlan have default gateway to the pix.
I have no idea whay is this happening link and port are all have hard coded speed.
ANY suggestion?
Chao
Vishwa
6 Replies 6
2go2marketing
You probably could have omitted the password part of your config. What are your speed/duplex settings on your 4503? If they are 100/full, try changing all of them to auto for the server link. Also, make sure the "flow control" settings are not being used on the server's NIC.
Tshi M
Level 5
Level 5
what do you get with
sh int status
sh int count er
Hi ,
I have attached the logs.
On the server end the speed is also 100 full .
Chao
Vishwa
Hi Vishwa,
I actually meant the output from your 4503 switch.
paolo bevilacqua
Which pix is that ? If you want performance for cross vlan traffic, use 4503 in L3 mode, or an high perfomance pix or router.
Hi ALL:
Thanks for the reply the issue is resolved,it was problem with Damm cables.
Chao
Vishwa
