Community Member
Slow WAN link - both sides on same IP segment
Inherited a goofy config. Site 1 and Site 2 are connected via a Pt to Pt T1. Users complined of slowness. Looking over config both sides are 172.16.x.x/16. One is .1 and one .2...but still same IP segment. Bridging is not enabled, but would braodcasts an other packets flow accross this?? Attached is interface config.
1 REPLY
Hall of Fame Super Silver
Re: Slow WAN link - both sides on same IP segment
Hello Dave,
yes they are a flat subnet so there can be impact of broadcast traffic.
IP subnetting is needed here.
IP proxy-arp can help in mitigating the effects on end systems enabled on lan segments.
Also the subnet is simply too big and the level of broadcast is high.
Really a bad design unless there were some requirements on servers.
Hope to help
Giuseppe
105
