Community Member
snmp,NAT and telnet questions
1.what does the command do ''snmp-server enable traps tty''
2.what is the meaning of the ''extended'' key-word ....ip nat inside source static tcp 10.0.0.126 5900 22.96.29.9 5900 extendable
3.How mant cucurrent connections are allowed .....line vty 5 15
1 REPLY
Silver
Re: snmp,NAT and telnet questions
1. When you configure the command snmp-server enable traps <…> on a Cisco device to send SNMP traps.
If you issue this command snmp-server enable traps tty it Enable TCP connection traps.
2. ip nat inside source {static {network local-network global-network mask} [extendable] [no-alias] [no-payload]
extendable - (Optional) Extends the translation.
3. Line vty 0 4 is to configure the first 5 default virtual terminal sessions. vty 5 15 is to configure the 10 optional virtual terminals
106
