Community Member
snmp
teach me how to configure snmp on a router...thanks
Re: snmp
hi,
Here you are this is one of the best in brief documents to learn SNMP:
http://www.netcraftsmen.net/welcher/papers/snmprouter.html
HTH, please do rate all helpful posts,
Mohammed Mahmoud.
Community Member
Re: snmp
1. What does the configuration mean?
2. Does the configuration "snmp-server host 150.40.0.30 CalyPSo" means i will get SNMP informations?
3. Do I still need to specify "snmp-server community CalyPSo RO 50" since I already have "snmp-server host 150.40.0.30 CalyPSo"?
access-list 50 permit 150.40.0.30
access-list 51 permit 150.40.0.31
snmp-server community NewLife RO 50
snmp-server community Cr1ck3T RW 53
snmp-server community Beauty! RW 51
snmp-server community CSCON@Tkit RO 55
snmp-server enable traps tty
snmp-server enable traps rtr
snmp-server host 150.40.0.31 CalyPSo
Re: snmp
In brief, community "CalyPSo" is a RO (Read Only) and only "150.40.0.30" can use it (50 in the end of the snmp command matches on ACL 50), the same goes for "NewLife", but for "Cr1ck3T" it is RW (read / write) and only addresses mathced by ACL 53 can use it (note that ACL 53 is not defined) and so on, the syntax is:
snmp-server community [ro | rw] [accesslist allowing access with this community string]
snmp-server host 150.40.0.30 CalyPSo --> This sends any and all SNMP traps the router sends to host 150.40.0.30 using the CalyPSo community.
Accordingly the 2 commands "snmp-server community CalyPSo RO 50" and "snmp-server host 150.40.0.30 CalyPSo" are independant, as the first sends snmp traps to "150.40.0.30", while the second enables the community "CalyPSo RO" to be used to grab snmp (and the 50 restricts that only "150.40.0.30" can use this community)
NOTE: Community strings act somewhat like passwords.
NOTE: There can be several community strings, and that each one may grant different forms of access
HTH, please do rate all helpful post,
Mohammed Mahmoud.
Community Member
Re: snmp
thansk! I already send my rate...
Bronze
Re: snmp
Mohammad answered this.
yes.
yes, if you want to poll the device with your snmp mgmt station.
220
