Webcast-Catalyst9k
Solve phase 1 issue in VPN betwwen 2 routers
I’m trying to establish a VPN connection between 2 routers (800-serie).
Site A is the central point. Site A has 2 Cisco routers: A1 and A2.
Site B is the remote point.
Currently a VNP connection is established between B and A1. It works very fine.
I just want to establish now the VPN connection between B and A2.
In the A2 router, I’ve added these lines:
crypto isakmp policy 10
 encr aes 256
 authentication pre-share
 group 2
 lifetime 43200
crypto isakmp key hr5*******9r6 address 0.0.0.0 0.0.0.0
crypto isakmp keepalive 60
crypto ipsec transform-set myset esp-aes 256 esp-sha-hmac
crypto map staticmap 10 ipsec-isakmp
 set peer public_ip_B
 set transform-set myset
 match address 101
access-list 101 permit ip 192.168.2.0 0.0.0.255 192.168.32.0 0.0.0.255
access-list 101 permit ip 192.168.4.0 0.0.0.255 192.168.32.0 0.0.0.255
access-list 101 permit ip 192.168.10.0 0.0.0.255 192.168.32.0 0.0.0.255
access-list 101 permit ip 192.168.20.0 0.0.0.255 192.168.32.0 0.0.0.255
The original config of the B router is:
 encr aes 256
 group 2
 lifetime 43200
 set peer public_ip_A1
 match address 101
access-list 101 permit ip 192.168.32.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 101 permit ip 192.168.32.0 0.0.0.255 192.168.4.0 0.0.0.255
access-list 101 permit ip 192.168.32.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 101 permit ip 192.168.32.0 0.0.0.255 192.168.20.0 0.0.0.255
On the B router, I execute these lines to alter the peer from A1 to A2:
 no set peer public_ip_A1
set peer public_ip_A2
The VPN connection does not get established. The debug info taken from B shows that the phase 1 remains on MM_NO_STATE.
Could someone help me to solve this issue? Thanks in advance.
Kind regards,
Guy
 encr aes 256
 group 2
 lifetime 43200
 match address 101
 encr aes 256
 group 2
 lifetime 43200
 match address 101
Kind regards,
Guy
Everyone's tags (1)
This clearly says that ISAKMP
This clearly says that ISAKMP main mode phase 1  has been failed. As per the config ISAKMP policy for the phase 1 is matching on both sides.
If peer IP has been changed, please clear the VPN session "clear ipsec sa peer <remote peer ip>" .
Also you can remove the crypto map from interface applied and then reconfigure.
Thank you for your help
Thank you for your help.
Changing the startup-config (new ip of the peer) and restarting solved this problem.
Guy
48
