SOLVED.
        This has been solved.
1 ACCEPTED SOLUTION
PPPoE w/ Static IP to separate DSL Modem?
here are the confiuration for PPOE
interface Dialer0
description PPPOE Dialer
  ip address negotiated
ip access-group XXXXXXX in
ip mtu XXXX
ip nat outside
encapsulation ppp
load-interval 30
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname username
ppp chap password 7 password
ppp pap sent-username uSERNAME password 7 PASSWORD
then adding the dialer to the interface
interface FastEthernet4
pppoe enable group global
pppoe-client dial-pool-number
you will have to enable the VPDN
vpdn enable
vpdn-group 1
request-dialin
  protocol pppoe
l2tp tunnel password 7
please let me know if this configuration is working for you or not.
Re: PPPoE w/ Static IP to separate DSL Modem?
Hello
If the ISP is providing you static ip then you will need to bridge the DSL Modem. The ISP provider will help you in bridging you the modem. For different providers the bridging setting on the modem would be different. Once your DSL modem is bridge you can directly use the static ip on the ISR physical interface.
SHine is right in the fact that the ISP modem will need to be in bridge mode, but you may also have to configure the IP and login info on the ethernet interface of your router, like so-
int gi0/1
ip address x.x.x.x x.x.x.x
ppp authentication pap chap callin
ppp pap sent-username password
no cdp enable
Ok, so I don't have to deal with VPDN groups or any of that kind of thing? I just get the ISP to bridge the modem, stick my IP address on the interface, enter my authentication and the link should work?
Hall of Fame Super Gold
The configuration you have been given above is wrong. You will need to configure ppp on a dialer interface. Search for "pppoe client" configuration examples.
interface Dialer0
ip mtu XXXX
ip nat outside
encapsulation ppp
load-interval 30
dialer pool 1
dialer-group 1
vpdn enable
vpdn-group 1
request-dialin
  protocol pppoe
293
