Some Help Would Be REALLY GOOD. WAN/NAT problem.
tyleradmin
Hi Guys.
I'm trying to configure a router for my client.
It's a 2911,  3 Gig interfaces with 1x EHWIC 1GE(RJ45/SFP)
I have an integrated firewall thru the security k9 bundle.
I've got a set of network static ips.
and the old network looks like this.
WAN -> HP MSR900 -> FIREWALL -> LOCAL LAN.
that said.
here's how it goes.
203.125.3.AA /30 (WAN) - > 220.255.13.BB/29 (Public IP) -> LAN 192.168.203.0/24.
But the new network goes like this.
WAN -> Cisco 2911 -> LOCAL LAN, 2 subnets 192.168.203.0/24 and 192.168.204.0/24.
The router will become the DHCP for 192.168.204.0/24 network only. the 203 network is being routed by the DHCP server from the current network.
The old firewall used to provide vpn services thru a simple pptp without authentication.
with my configuration as per below. im able to reach the next hop and google thru the router, but unable to reach the internet from the inside lan.
Ok, here's the question.
how can i configure the router to be able to route packets properly?
and is my configuration for the pptp correct?
that said,
Building configuration...
Current configuration : 6165 bytes
! Last configuration change at 16:19:22 UTC Tue Aug 6 2013 by admin
version 15.3
hostname POWERRANGERS
boot-start-marker
boot system flash:c2900-universalk9-mz.SPA.153-2.T.bin
boot-end-marker
no logging buffered
no aaa new-model
ip cef
ip dhcp excluded-address 192.168.204.1 192.168.204.30
ip dhcp excluded-address 192.168.204.251 192.168.204.254
ip dhcp pool Internal204NWPool
import all
network 192.168.204.0 255.255.255.0
dns-server 8.8.8.8 8.8.4.4
default-router 192.168.204.1
lease 5
ip name-server 8.8.8.8
ip name-server 8.8.4.4
no ipv6 cef
vpdn enable
vpdn-group HLFVPN
! Default PPTP VPDN group
accept-dialin
  protocol pptp
  virtual-template 1
crypto pki trustpoint TP-self-signed-2440568946
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2440568946
revocation-check none
rsakeypair TP-self-signed-2440568946
crypto pki certificate chain TP-self-signed-2440568946
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32343430 35363839 3436301E 170D3133 30383035 31343533
  30325A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 34343035
  36383934 3630819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100B74E DD1317E6 F5D9E1B0 AC39C104 9E070D64 6CCD9E85 2F6E8D77 22B52996
  737D2464 0F2A1913 D1240A3A 136F9D12 C0432048 9DA07BFB E04E1887 1B3B3A41
  1BD53CBD B048E04C 6DE71BF3 1884F54E 5E399881 BEFACA71 0C4488CE AB0AFFCE
  32D5A65C BE4F44B1 05CC6CFF 816E0CBC 69FB5D00 0397BB6A D47DC5B4 D19BAAF8
  65350203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 14F74D69 4D5F534F B1FBF5D2 99266BB1 759234C3 BD301D06
  03551D0E 04160414 F74D694D 5F534FB1 FBF5D299 266BB175 9234C3BD 300D0609
  2A864886 F70D0101 05050003 8181004A B7ED9E99 DE0195EC 70128B8D D9369539
  D1DC8616 EA85159F D6360732 42AF9C64 2C328D7D 03AAEFCB 57EE3829 D91B78F3
  89B82844 8BC6F280 6844B7CE 858FDFEE B3AC3132 1DDA0DB3 8FD3D7F8 B34797F1
  6EA2066C 034E57C9 76B39621 6E9ECC85 F494E2E8 A00A431C 5BF3A0E8 5913D7A5
  B11124E0 2971A2FE 8B102F4E 5EAE94
            quit
license udi pid CISCO2911/K9 sn FGL171711LA
license accept end user agreement
username admin privilege 15 secret 4 yEpCjsAh.TR7Tes/KptX76P3WCk6hm100cT7/GVtxKI
redundancy
no ip ftp passive
bridge irb
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description SingNetWANLink
ip address 203.125.3.AA 255.255.255.252
ip virtual-reassembly in
duplex full
speed 100
interface GigabitEthernet0/1
description LAN192.168.203.0LINK
ip address 192.168.203.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/2
description LAN192.168.204.0LINK
ip address 192.168.204.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/0/0
ip address 10.10.10.10 255.255.255.0
duplex auto
speed auto
media-type rj45
ip local pool WANPOOL 220.255.13.BB
ip forward-protocol nd
no ip http server
ip http authentication local
ip http secure-server
ip nat inside source list 101 pool WANPOOL overload
ip route 0.0.0.0 0.0.0.0 203.125.3.89
access-list 101 permit ip any any
access-list 101 permit ip 192.168.203.0 0.0.0.255 any
access-list 102 permit ip 192.168.204.0 0.0.0.255 any
control-plane
banner login ^CUnauthorized Login Will Be Prosecuted.^C
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
Can you post the existing config as it sits now?
The following config should work:
int g0/0
ip nat outside
ip nat inside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
ip nat pool WANPOOL 220.255.13.x 220.255.13.x prefix-length 24
access-list 101 permit ip 192.168.204.0 0.0.0.255 any
Your 192.168.204.0/24 subnet was not listed in your nat acl, and if you'll notice the original post was part of acl 102. I added that line to 101. You needed to fix your nat pool as local pools are used for VPN connections generally, but not used in the case of nat.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
12 Replies 12
mfurnival
Level 4
Level 4
You need "ip nat outside" on your WAN interface.
hi, after i put int the ip nat outside, the i cant ping the outside interface anymore.
Did you remove the line in the ACL as per Alain's advice too?
Can you ping 8.8.8.8 from the router?
cadet alain
also remove this :
Alain
tyleradmin
also, where do i add in the line for the leased static ips?
you may use one or more in your WAN pool and one or more for static NAT statements for port forwarding.
Alain
tyleradmin
alright. let you guys know again :>
Hi , Can you remove below line :
then replace it with :
ip nat pool WANPOOL 220.255.13.xx 220.255.13.yy netmask 255.255.255.248 .
tyleradmin
Hi guys,
I cant seem to get the link up any more.
When i have the nat overload on the WANPOOL, it doesnt't work.
I'm only able to get it up thru the use of the ip nat inside source.........G0/0 Overload
Which also means that when i type Show ip nat translations,
all the addresses are actually originating from this. 203.125.3.AA /30
which is the WAN link ip instead of the leased static ips.
Help me i'm dying lol.
int g0/0
ip nat outside
ip nat inside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
HTH,
John
Hi John,
Good day. Is the line..
used for the public ip pool?
cause right now, my natting is only done on the WAN link IP. which is the IP between my current router and the net hop.
i need to nat it out on the IP that my ISP gave to me. any help?
tyleradmin
Here's my configuration as of now.
version 15.3
hostname Router
boot-start-marker
boot-end-marker
logging userinfo
no aaa new-model
ip cef
ip dhcp excluded-address 192.168.204.250 192.168.204.254
import all
lease 5
no ipv6 cef
vpdn enable
vpdn-group HLFVPN
accept-dialin
  protocol pptp
  virtual-template 1
  69666963 6174652D 32343430 35363839 3436301E 170D3133 30383037 31383335
  31385A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  81009B1C 60456DCD 9D14BC5B 1B8976D6 55D0D776 70728893 ECD5E6DD 8FDC71D9
  F9F42447 0F3028B7 786E9CA3 07AE1738 483EE7DD 95BA1725 A9A9C2D4 B3F5DE5E
  C671A88F D765FE5A 2CF0CB72 7CF0D87A 985BB5CE A8D4B688 3A85AB99 660BC7F1
  E3DE0718 63761430 F15BCDA6 3EA2A130 532A2E10 D6529266 FCE9A8FD FEDC299D
  8E710203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 14C4AEC7 D9AFD8EE 7399FACA D70AFF56 B14DEF0A 9A301D06
  03551D0E 04160414 C4AEC7D9 AFD8EE73 99FACAD7 0AFF56B1 4DEF0A9A 300D0609
  2A864886 F70D0101 05050003 81810088 E6ED80B6 3313D1D3 E7CE64F7 1C118DCB
  99D8D31D 1874F43B 6A3C6B07 991BA461 BB1BA030 51E20FC9 F2E22289 E7F3BA25
  97A26F27 C0141E75 AD7D626E 14C7E388 089D0C21 1C02DD03 50366135 237434E6
  53AEFF8C 7D1A33EC 385C7CA8 A27321B6 54FE9C3C 7559669F C429C6F4 BB869D81
  F1AE980D 422983B8 04E8E7AE 878CD3
            quit
redundancy
no ip address
shutdown
ip address 220.255.13.YY 255.255.255.248 secondary
ip address 203.125.3.XX 255.255.255.252
ip nat outside
duplex full
speed 100
ip nat inside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
interface Virtual-Template1
ip unnumbered GigabitEthernet0/0
peer default ip address pool VPNPOOL
no keepalive
ip local pool VPNPOOL 192.168.204.10 192.168.204.20
no ip http server
ip nat inside source list 101 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 203.125.3.XX
logging trap debugging
logging host 10.10.10.5
route-map 1 permit 10
access-list 101 permit ip 10.10.10.0 0.0.0.255 any
control-plane
line con 0
line aux 0
line 2
no exec
transport input all
stopbits 1
line vty 0 4
login local
transport input all
line vty 5 15
login local
transport input all
end
