SPA-1XOC48 diagnostic problem ?
i have a 7600 with sup-720-3B and 12.2.33SXI3 ios version. also i have a 7600-sip-400 with SPA-1xOC48POS\RPR inside. when i do show module i see that the sip-400 and the spa are in status OK but below at the diagnostic i see the spa in unknown.
i can see the spa slot at the running config and also able to configure it.
is this a known issue with spa cards?
thanks,
Avi
1 REPLY
Re: SPA-1XOC48 diagnostic problem ?
Hi Avi,
Would i be assuming that you are seeing something similar to the following excerpt of a "show module"?
Mod  Online Diag Status
 1  Pass
1/0 Unknown
1/1 Unknown
 3  Pass
 4  Pass
 5  Pass
If you do a "show diagbus" the SPA information should indicate that the status is ok
Showing the diag status of the SPAs as unknown is expected behaviour. In SXI the only diagnostic test that is run on SIP-400 spa's is "TestLoopback", and this is not supported (the test will be skipped). Currently there is no workaround for SXI3.
Nelson
177
