Community Member
Spann port
I have configured a spann port on my CAT6509, source port is part of 4 port-channel trunk,My question is , when I monitor the traffic on destination port ,Is this monitoring only for this port or all 4 ports in channel group ?
Re: Spann port
I'm afraid you cannot do it. You should SPAN the Po interface instead. Here is from the config guide:
A port-channel interface (an EtherChannel) can be a SPAN source, but you cannot configure active member ports of an EtherChannel as SPAN source ports. Inactive member ports of an EtherChannel can be configured as SPAN sources but they are put into the suspended state and carry no traffic.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/span.html#wp1079189
Kevin Dorrell
Luxembourg
Community Member
Re: Spann port
Please can you tell me what will be the command on Cat IOS ,cos there is no PO interface there.
Regards.
Re: Spann port
340
