SSH to WAN with static nat won't work (dual ISP)
Vadim Doroginin
Hello all!
Everything worked fine untill... I introduced second ISP for redundancy.
I have C881 ISR installation with two ISP, both are NAT outside with failover.
When both ISP work fine, ISP1 is used to NAT internal users to outside internet and ISP2 is used to build DM_VPN Tunnel (Spoke).
Both ISPs are tracked by IP SLA.
When ISP1 goes down internal users are switched to NAT through ISP2.
When ISP2 goes down DMVPN Tunnel is switched to build through ISP1.
ISP1 - Fa4.41
ISP2 - Di0 through Fa4.42
Here is my problem: I can't SSH into ISP interfaces. Router actively refuses connection.
I narrowed down problem to following lines:
ip nat inside source static tcp 10.50.255.10 20502 isp1-ip.x.y.z 20502 extendable
ip nat inside source static udp 10.50.255.10 20502 isp1-ip.x.y.z 20502 extendable
ip nat inside source static tcp 10.50.255.10 3389 isp1-ip.x.y.z 23389 extendable
ip nat inside source static tcp 10.50.255.10 20502 isp2-ip.x.y.z 20502 extendable
ip nat inside source static udp 10.50.255.10 20502 isp2-ip.x.y.z 20502 extendable
ip nat inside source static tcp 10.50.255.10 3389 isp2-ip.x.y.z 23389 extendable
I have to remove these lines, then reload my router... then SSH starts working on ISP interfaces.
If I add these lines after my router is reloaded, SSH continues working until I reboot it.
So the problem is: if these lines are present at router startup, SSH won't work.
I have a workaround: make static nat isp:xxxxx - > 10.50.255.1:22, however I'm afraid that there is something else I'm missing in this installation which may cause more problems with more complex troubleshooting.
I've done my homework: there is pretty much people with the same problem and no solution (here is small part of them).
Here is what I've already tried:
  • remove access-groups from external interfaces - won't help
  • remove static NAT rules - won't help until reload
  • remove NAT completely (all rules + nat inside/outside on interfaces) - yep, it works, however there is veryyyy small problem: I need NAT to access the Internet
  • shutdown one of ISP - failover works great, however SSH still not working
  • debug ip packet, routing, policy routing, nat: I get SYN from remote peer, then router responds with RST after FIBipv4-packet-proc: packet routing failed. Knowing this didn't help - why routing failed? packet comes with dst=ip-of-router... what is in it to fail?
Full config follows.
! Last configuration change at 22:51:41 GMT+4 Tue Oct 15 2013
version 15.3
no service pad
service timestamps debug datetime
service password-encryption
hostname archimed-gw
boot-start-marker
boot system flash:c880data-universalk9-mz.153-3.M.bin
boot-end-marker
aaa new-model
aaa session-id common
memory-size iomem 10
clock timezone GMT+4 4 0
ip dhcp excluded-address 10.50.255.1 10.50.255.9
ip dhcp pool home_lan
network 10.50.255.0 255.255.255.0
domain-name xxx.loc
dns-server 10.50.255.1
default-router 10.50.255.1
option 150 ip 10.177.20.1
ip dhcp pool Archimed-VAIO-WiFi
host 10.50.255.10 255.255.255.0
client-identifier 0108.edb9.ad80.2b
ip dhcp pool Archimed-VAIO-Eth
host 10.50.255.15 255.255.255.0
client-identifier 01f0.bf97.063a.80
ip dhcp pool Legova-Lenovo-WiFi
host 10.50.255.12 255.255.255.0
client-identifier 0100.16eb.2b0a.a4
ip domain name xxx.loc
ip cef
no ipv6 cef
license udi pid CISCO881-PCI-K9 sn FCZ1715C1A6
track 1 ip sla 1 reachability
delay down 60 up 60
track 2 ip sla 2 reachability
delay down 60 up 60
ip ssh port 7522 rotary 1
ip ssh version 2
crypto isakmp policy 11
encr aes 256
authentication pre-share
group 5
crypto isakmp key xxx address 0.0.0.0
crypto ipsec transform-set aes256-sha esp-aes 256 esp-sha-hmac
mode transport
crypto ipsec profile dmvpn
set transform-set aes256-sha
set pfs group5
interface Tunnel10
description DM_vpn
ip address 192.168.254.10 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp authentication xxx
ip nhrp map multicast hub1.x.y.z
ip nhrp map 192.168.254.254 hub1.x.y.z
ip nhrp map 192.168.254.1 hub2.x.y.z
ip nhrp map multicast hub2.x.y.z
ip nhrp network-id 1
ip nhrp nhs 192.168.254.1
ip nhrp nhs 192.168.254.254
ip nhrp registration no-unique
ip virtual-reassembly in
ip tcp adjust-mss 1360
ip ospf network broadcast
ip ospf priority 0
tunnel source Dialer0
tunnel mode gre multipoint
tunnel key 8
tunnel route-via Dialer0 mandatory
tunnel protection ipsec profile dmvpn
interface FastEthernet0
no ip address
shutdown
interface FastEthernet1
no ip address
shutdown
interface FastEthernet2
no ip address
shutdown
interface FastEthernet3
switchport access vlan 10
no ip address
interface FastEthernet4
description Internet TRUNK
no ip address
ip access-group ext_if in
duplex auto
speed auto
interface FastEthernet4.41
description Qwerty
encapsulation dot1Q 41
no ip dhcp client request domain-name
no ip dhcp client request dns-nameserver
ip address dhcp hostname QWERTY1
no ip redirects
ip nat outside
ip virtual-reassembly in max-reassemblies 1024
interface FastEthernet4.42
description Smile
encapsulation dot1Q 42
ip address dhcp
no ip redirects
pppoe enable group global
pppoe-client dial-pool-number 1
interface Vlan1
no ip address
interface Vlan10
description USER_vlan
ip address 10.50.255.1 255.255.255.0
ip nat inside
ip policy route-map LAN2WAN
interface Dialer0
description Smile
bandwidth 100000
ip address negotiated
no ip redirects
ip mtu 1492
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
ppp authentication chap callin
ppp chap hostname xxx
ppp chap password 7 yyyy
ppp ipcp dns reject
no cdp enable
router ospf 5
router-id 10.50.255.1
passive-interface Dialer0
passive-interface FastEthernet4
passive-interface FastEthernet4.41
passive-interface FastEthernet4.42
network 10.50.255.0 0.0.0.255 area 10.50.255.0
network 192.168.254.0 0.0.0.255 area 0.0.0.0
ip local policy route-map Local
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns view xxx-local
domain name xxx.loc
domain name-server  10.177.14.50
domain name-server  192.168.77.1
ip dns view default
domain name-server  8.8.8.8
domain name-server  8.8.4.4
ip dns view-list xxx-split
view xxx-local 1
  restrict name-group 2
view default 2
  restrict name-group 1
ip dns name-list 1 deny .*xxx.LOC
ip dns name-list 1 permit .*
ip dns name-list 2 permit .*xxx.LOC
ip dns name-list 2 deny .*
ip dns server view-group xxx-split
ip dns server
ip nat inside source route-map ISP1_NAT interface FastEthernet4.41 overload
ip nat inside source route-map ISP2_NAT interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 isp1-gw.x.y.z track 1
ip route 0.0.0.0 0.0.0.0 isp2-gw.x.y.z track 2
ip route 46.246.32.113 255.255.255.255 Dialer0 track 2
ip route 37.220.6.160 255.255.255.255 Dialer0 track 2
ip route 37.220.6.161 255.255.255.255 Dialer0 track 2
ip route 95.143.192.249 255.255.255.255 Dialer0 track 2
ip access-list standard ISP1_ROUTE
permit isp1-ip.x.y.z
ip access-list standard ISP2_ROUTE
permit isp2-ip.x.y.z
ip access-list standard NAT_ACL
permit 10.50.255.0 0.0.0.255
ip access-list extended ext_if
deny   tcp any any eq telnet
deny   udp any any eq domain
deny   tcp any any eq 22
deny   tcp any any eq 3389
deny   udp any any eq tftp
permit ip any any
ip sla auto discovery
ip sla 1
icmp-echo 194.87.0.50 source-interface FastEthernet4.41
threshold 500
timeout 3000
frequency 3
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 194.87.0.50 source-interface Dialer0
threshold 500
timeout 3000
frequency 3
ip sla schedule 2 life forever start-time now
logging history size 500
logging history debugging
logging trap debugging
logging host 10.50.255.10
route-map LAN2WAN permit 10
match ip address NAT_ACL
set default interface FastEthernet4.41
route-map Local permit 10
match ip address ISP1_ROUTE
set ip default next-hop isp1-gw.x.y.z
route-map Local permit 20
match ip address ISP2_ROUTE
set ip default next-hop isp2-gw.x.y.z
route-map ISP2_NAT permit 10
match interface Dialer0
route-map ISP1_NAT permit 10
match interface FastEthernet4.41
control-plane
line con 0
privilege level 15
logging synchronous
no modem enable
line aux 0
line vty 0 4
privilege level 15
logging synchronous
rotary 1
transport input ssh
ntp server ip ru.pool.ntp.org
event manager applet DMVPNISPDown
event track 2 state down
action 10 cli command "enable"
action 20 cli command "configure terminal"
action 30 cli command "interface Tunnel10"
action 40 cli command "shutdown"
action 50 cli command "tunnel source FastEthernet4.41"
action 60 cli command "tunnel route-via FastEthernet4.41 mandatory"
action 70 cli command "no shutdown"
action 90 cli command "end"
event manager applet DMVPNISPUp
event track 2 state up
action 50 cli command "tunnel source Dialer0"
action 60 cli command "tunnel route-via Dialer0 mandatory"
event manager applet NATISPDown
event track 1 state down
action 30 cli command "route-map LAN2WAN permit 10"
action 40 cli command "no set default interface Dialer0"
action 41 cli command "no set default interface FastEthernet4.41"
action 50 cli command "set default interface Dialer0"
action 60 cli command "end"
action 70 cli command "clear ip nat translation *"
action 80 cli command "clear ip nat translation forced"
event manager applet NATISPUp
event track 1 state up
action 50 cli command "set default interface FastEthernet4.41"
end
Terminal output when remote peer tries to connect to router:7522
Oct 15 17:53:04: IP: s=remote-ip.x.y.z (FastEthernet4.41), d=isp1-ip.x.y.z, len 52, input feature
Oct 15 17:53:04:     TCP src=8380, dst=7522, seq=999405847, ack=0, win=8192 SYN, Common Flow Table(5), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Oct 15 17:53:04:     TCP src=8380, dst=7522, seq=999405847, ack=0, win=8192 SYN, Stateful Inspection(7), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Oct 15 17:53:04:     TCP src=8380, dst=7522, seq=999405847, ack=0, win=8192 SYN, Virtual Fragment Reassembly(36), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Oct 15 17:53:04:     TCP src=8380, dst=7522, seq=999405847, ack=0, win=8192 SYN, Access List(42), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Oct 15 17:53:04:     TCP src=8380, dst=7522, seq=999405847, ack=0, win=8192 SYN, Virtual Fragment Reassembly After IPSec Decryption(52), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Oct 15 17:53:04:     TCP src=8380, dst=7522, seq=999405847, ack=0, win=8192 SYN, NAT Outside(80), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Oct 15 17:53:04:     TCP src=8380, dst=7522, seq=999405847, ack=0, win=8192 SYN, MCI Check(94), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Oct 15 17:53:04: FIBipv4-packet-proc: route packet from FastEthernet4.41 src remote-ip.x.y.z dst isp1-ip.x.y.z
Oct 15 17:53:04: FIBfwd-proc: Default:isp1-ip.x.y.z/32 receive entry
Oct 15 17:53:04: FIBipv4-packet-proc: packet routing failed
Oct 15 17:53:04: IP: tableid=0, s=remote-ip.x.y.z (FastEthernet4.41), d=isp1-ip.x.y.z (FastEthernet4.41), routed via RIB
Oct 15 17:53:04: IP: s=remote-ip.x.y.z (FastEthernet4.41), d=isp1-ip.x.y.z (FastEthernet4.41), len 52, output feature
Oct 15 17:53:04:     TCP src=8380, dst=7522, seq=999405847, ack=0, win=8192 SYN, Post-routing NAT Outside(24), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Oct 15 17:53:04:     TCP src=8380, dst=7522, seq=999405847, ack=0, win=8192 SYN, Common Flow Table(27), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Oct 15 17:53:04:     TCP src=8380, dst=7522, seq=999405847, ack=0, win=8192 SYN, Stateful Inspection(28), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Oct 15 17:53:04: IP: s=remote-ip.x.y.z (FastEthernet4.41), d=isp1-ip.x.y.z (FastEthernet4.41), len 52, rcvd 3
Oct 15 17:53:04: IP: s=remote-ip.x.y.z (FastEthernet4.41), d=isp1-ip.x.y.z, len 52, stop process pak for forus packet
Oct 15 17:53:04: IP: s=remote-ip.x.y.z (FastEthernet4.41), d=isp1-ip.x.y.z, len 52, enqueue feature
Oct 15 17:53:04:     TCP src=8380, dst=7522, seq=999405847, ack=0, win=8192 SYN, TCP Adjust MSS(5), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Oct 15 17:53:04: IP: s=isp1-ip.x.y.z (local), d=remote-ip.x.y.z, len 40, local feature
Oct 15 17:53:04:     TCP src=7522, dst=8380, seq=0, ack=999405848, win=0 ACK RST, NAT(2), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Oct 15 17:53:04: IP: s=isp1-ip.x.y.z (local), d=remote-ip.x.y.z, len 40, policy match
Oct 15 17:53:04: IP: route map Local, item 10, permit
Oct 15 17:53:04: IP: s=isp1-ip.x.y.z (local), d=remote-ip.x.y.z (FastEthernet4.41), len 40, policy routed
Oct 15 17:53:04: IP: local to FastEthernet4.41 isp1-gw.x.y.z
Oct 15 17:53:04: IP: s=isp1-ip.x.y.z (local), d=remote-ip.x.y.z (FastEthernet4.41), len 40, local feature
Oct 15 17:53:04:     TCP src=7522, dst=8380, seq=0, ack=999405848, win=0 ACK RST, Policy Routing(3), rtype 2, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Oct 15 17:53:04: IP: s=isp1-ip.x.y.z (local), d=remote-ip.x.y.z (FastEthernet4.41), len 40, sending
Oct 15 17:53:04: IP: s=isp1-ip.x.y.z (local), d=remote-ip.x.y.z (FastEthernet4.41), len 40, output feature
Oct 15 17:53:04:     TCP src=7522, dst=8380, seq=0, ack=999405848, win=0 ACK RST, Post-routing NAT Outside(24), rtype 2, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Oct 15 17:53:04:     TCP src=7522, dst=8380, seq=0, ack=999405848, win=0 ACK RST, Common Flow Table(27), rtype 2, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Oct 15 17:53:04:     TCP src=7522, dst=8380, seq=0, ack=999405848, win=0 ACK RST, Stateful Inspection(28), rtype 2, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
archimed-gw#
Oct 15 17:53:04:     TCP src=7522, dst=8380, seq=0, ack=999405848, win=0 ACK RST, NAT ALG proxy(59), rtype 2, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Oct 15 17:53:04: IP: s=isp1-ip.x.y.z (local), d=remote-ip.x.y.z (FastEthernet4.41), len 40, sending full packet
Oct 15 17:53:04: SSH2 0: channel window adjust message received 9492
Oct 15 17:53:05: IP: s=remote-ip.x.y.z (FastEthernet4.41), d=isp1-ip.x.y.z, len 48, input feature
Oct 15 17:53:05:     TCP src=8380, dst=7522, seq=999405847, ack=0, win=8192 SYN, Common Flow Table(5), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Oct 15 17:53:05:     TCP src=8380, dst=7522, seq=999405847, ack=0, win=8192 SYN, Stateful Inspection(7), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Oct 15 17:53:05:     TCP src=8380, dst=7522, seq=999405847, ack=0, win=8192 SYN, Virtual Fragment Reassembly(36), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Oct 15 17:53:05:     TCP src=8380, dst=7522, seq=999405847, ack=0, win=8192 SYN, Access List(42), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Oct 15 17:53:05:     TCP src=8380, dst=7522, seq=999405847, ack=0, win=8192 SYN, Virtual Fragment Reassembly After IPSec Decryption(52), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Oct 15 17:53:05:     TCP src=8380, dst=7522, seq=999405847, ack=0, win=8192 SYN, NAT Outside(80), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Oct 15 17:53:05:     TCP src=8380, dst=7522, seq=999405847, ack=0, win=8192 SYN, MCI Check(94), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Oct 15 17:53:05: FIBipv4-packet-proc: route packet from FastEthernet4.41 src remote-ip.x.y.z dst isp1-ip.x.y.z
Oct 15 17:53:05: FIBfwd-proc: Default:isp1-ip.x.y.z/32 receive entry
Oct 15 17:53:05: FIBipv4-packet-proc: packet routing failed
Oct 15 17:53:05: IP: tableid=0, s=remote-ip.x.y.z (FastEthernet4.41), d=isp1-ip.x.y.z (FastEthernet4.41), routed via RIB
Oct 15 17:53:05: IP: s=remote-ip.x.y.z (FastEthernet4.41), d=isp1-ip.x.y.z (FastEthernet4.41), len 48, output feature
Oct 15 17:53:05:     TCP src=8380, dst=7522, seq=999405847, ack=0, win=8192 SYN, Post-routing NAT Outside(24), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Oct 15 17:53:05:     TCP src=8380, dst=7522, seq=999405847, ack=0, win=8192 SYN, Common Flow Table(27), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Oct 15 17:53:05:     TCP src=8380, dst=7522, seq=999405847, ack=0, win=8192 SYN, Stateful Inspection(28), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Oct 15 17:53:05: IP: s=remote-ip.x.y.z (FastEthernet4.41), d=isp1-ip.x.y.z (FastEthernet4.41), len 48, rcvd 3
Oct 15 17:53:05: IP: s=remote-ip.x.y.z (FastEthernet4.41), d=isp1-ip.x.y.z, len 48, stop process pak for forus packet
Oct 15 17:53:05: IP: s=remote-ip.x.y.z (FastEthernet4.41), d=isp1-ip.x.y.z, len 48, enqueue feature
Oct 15 17:53:05:     TCP src=8380, dst=7522, seq=999405847, ack=0, win=8192 SYN, TCP Adjust MSS(5), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Oct 15 17:53:05: IP: s=isp1-ip.x.y.z (local), d=remote-ip.x.y.z, len 40, local feature
Oct 15 17:53:05:     TCP src=7522, dst=8380, seq=0, ack=999405848, win=0 ACK RST, NAT(2), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Oct 15 17:53:05: IP: s=isp1-ip.x.y.z (local), d=remote-ip.x.y.z, len 40, policy match
Oct 15 17:53:05: IP: route map Local, item 10, permit
Oct 15 17:53:05: IP: s=isp1-ip.x.y.z (local), d=remote-ip.x.y.z (FastEthernet4.41), len 40, policy routed
Oct 15 17:53:05: IP: local to FastEthernet4.41 isp1-gw.x.y.z
Oct 15 17:53:05: IP: s=isp1-ip.x.y.z (local), d=remote-ip.x.y.z (FastEthernet4.41), len 40, local feature
Oct 15 17:53:05:     TCP src=7522, dst=8380, seq=0, ack=999405848, win=0 ACK RST, Policy Routing(3), rtype 2, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Oct 15 17:53:05: IP: s=isp1-ip.x.y.z (local), d=remote-ip.x.y.z (FastEthernet4.41), len 40, sending
Oct 15 17:53:05: IP: s=isp1-ip.x.y.z (local), d=remote-ip.x.y.z (FastEthernet4.41), len 40, output feature
Oct 15 17:53:05:     TCP src=7522, dst=8380, seq=0, ack=999405848, win=0 ACK RST, Post-routing NAT Outside(24), rtype 2, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Oct 15 17:53:05:     TCP src=7522, dst=8380, seq=0, ack=999405848, win=0 ACK RST, Common Flow Table(27), rtype 2, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Oct 15 17:53:05:     TCP src=7522, dst=8380, seq=0, ack=999405848, win=0 ACK RST, Stateful Inspection(28), rtype 2, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
archimed-gw#
Oct 15 17:53:05:     TCP src=7522, dst=8380, seq=0, ack=999405848, win=0 ACK RST, NAT ALG proxy(59), rtype 2, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Oct 15 17:53:05: IP: s=isp1-ip.x.y.z (local), d=remote-ip.x.y.z (FastEthernet4.41), len 40, sending full packet
Oct 15 17:53:05: SSH2 0: channel window adjust message received 8206
Please, help!
9 Replies 9
I´m stuck with the same annoying issue. It´s incredible that no one came across with this, the info you provided here couldn't be more complete.
Have you ever found any solution?
Nope, I had to remove one of translations. I can live with that because it's not critical for me.
If it is critical there is two solutions:
1. Use BGP - it will solve all your problems :).
2. Use one static NAT. When ISP is down rewrite NAT rules inside EEM applet.
Hi!
By BGP, item #1, you mean inter-VRF routing using this protocol?
This magically solves these issues? If so i´ll try it...
Nope, I mean actual BGP with your own AS+subnet and BGP-peering with both ISPs.
Long story short: some internal resource (say http server 192.168.1.123:80) can not be published to internet with dual active IP addresses from your ISPs.
  • You can easily publish one resource to one IP (say x.x.x.x:80=192.168.1.123:80) and another resource to second IP (say y.y.y.y:443=192.168.1.123:443).
  • You can failover resource from first IP to second IP and back to the first IP at your wish or by means of EEM applets.
  • You can publish a resource on an alternative IP for some specific subnet (say y.y.y.y:80=192.168.1.123:80 for z.z.z.0/24 and x.x.x.x:80=192.168.1.123:80 for the rest of internet).
There is simple explanation for this limitation: even when incoming packet is correctly routed, NATed and firewalled from some public IP to one of your public IPs (say w.w.w.w:9999 is connecting to secondary IP y.y.y.y:80 which correctly translates to w.w.w.w:9999->192.168.1.123:80), the outgoing packet will always have a specific route through a specific IP (say a response is sent from 192.168.1.123:80 to w.w.w.w:9999 which translates to x.x.x.x:80->w.w.w.w:9999). You can see why it won't work because w.w.w.w expectes a response from y.y.y.y, not from x.x.x.x.
So go ahead and remove duplicate static-NAT lines from your config.
Ok thanks for your detailed explanation.
My solution was making a SNAT for one of the static-nat because in my scenario there is no way to publish this service on a different IP Address. Example: 192.168.20.5:80 has to be accessible from internet, any public source address and translated x.x.x.x:5955->192.168.20.5:80 AND y.y.y.y:5955->192.168.20.5:80, both Active simultaneously.
Regards.
Philip D'Ath
I've seen this problem before.  It was an IOS bug.  From memory, we hit it in 15.4(3)Mx train.  I think it was in some others as well.
We resolved the issue by upgrading to a newer version of IOS.
Yes! I am aware of that, I successfully configured routers running newer IOS without this issue, but we have a few 18xx that can not be pushed beyond 15.1.x version
Consider downgrading then until the issue goes away.
Just for the record..
Unfortunately the "newer" version that works exactly with the configuration layout we are using is 15.0M.
It´s pretty old and we have had two important issues:
1- Auth by radius server fails: Passwords sent to the server are messed up (confirmed by radius debugging)
2- Stability is bad: Two router hangs in one week.
So we can not consider this an option.
BTW thanks for your recommendation.
