SSH
guys in out company we are config ssh on out routers and swithes but requirmnet is that it shd support both version (1 and 2) i know how to enable ssh but is there any specific comand to enable these both ??? can someone help me plz
Re: SSH
No you can enable either of the versions but not both
Why is it a requirement to support both versions? If your devices support SSHv2, i would recommend configuring v2 while the non supporting ones can be left at v1
Narayan
Re: SSH
since this is regarding ssh, i have this cisco 2801 that i wanted to enable ssh. however i cannot enter commands such as "cry key generate rsa" and "ip ssh ..". Don't know y? they are unrecognized commands!
IOS 12.4(20)T1.
any hints y?
thnx
Re: SSH
It appears that you don't have a crypto version IOS. You will need to download a crypto IOS, and upgrade the IOS.
HTH,
Mark
Re: SSH
I was about to answer my issue since i just found out in the release notes...but you're too fast. So i'll rate you for that.
thnx
Hall of Fame Super Silver
Re: SSH
Robert
Since Mark did correctly analyze your problem and suggest the correct solution, I am surprised that you rated his as a 2. I think that he deserves better and I will give him better.
Rick
Re: SSH
Thanks Rick!
I appreciate the support,
Mark
126
