08-18-2008 07:57 PM - edited 03-03-2019 11:11 PM
I'm having two separate issues with my configuration which I would really appreciate some help with. The first being that when using a Zone Based Firewall configuration I'm unable to access my internal network from a SSL VPN Connection. When I remove the Zone's from the interfaces I'm then able to access the internal network. And the second being that I'm unable to access the internet from the SSL VPN Connection weather the ZFW is enabled or not. Attached is my config and any help given would be greatly appreacited.
08-22-2008 12:46 PM
Here is the guide for the SSL VPN. Follow the below guide for the configuration and more details about it .
02-27-2009 08:20 AM
I am having this exact same issue. Firewall up...no VPN to Intranet....firewall down and it works.
Did you find any answers?
