02-23-2012 05:01 AM - edited 03-04-2019 03:24 PM
Im trying to Connect a 2960-S Catalyst Switch to a 3560 Catalyst Switch. It worth pointing out im newish to switching although i know some commands and what they do
This is my first time connecting 2 switches together.
They are connected via a crossover cable and have green lights flashing on the connected ports
When i run "show CDP neighbours it sees the new switch
Unable to ping new switch...just timesout
Here is the the interface on the 3650
GigabitEthernet0/40 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 001b.532f.8428 (bia 001b.532f.8428)
Description: Uplink to Switch 2
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:00, output 00:00:01, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1000 bits/sec, 2 packets/sec
5 minute output rate 3000 bits/sec, 4 packets/sec
6579 packets input, 477123 bytes, 0 no buffer
Received 6334 broadcasts (0 multicast)
1 input errors, 1 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 6337 multicast, 0 pause input
13864 packets output, 1323788 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
Port Mode Encapsulation Status
Gi0/40 on 802.1q trunking 2
Port Vlans allowed on trunk
Gi0/40 1-4094
Port Vlans allowed and active in management domain
Gi0/40 1-4,6-8
Port Vlans in spanning tree forwarding state and not pruned
Gi0/40 3-4,6-8
Here is the interface on the 2960
GigabitEthernet1/0/40 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 2c3f.38b9.baa8 (bia 2c3f.38b9.baa8)
Last input 00:00:01, output 00:00:00, output hang never
5 minute input rate 3000 bits/sec, 5 packets/sec
5 minute output rate 1000 bits/sec, 2 packets/sec
16674 packets input, 1591566 bytes, 0 no buffer
Received 16336 broadcasts (13406 multicasts)
0 watchdog, 13414 multicast, 0 pause input
7976 packets output, 576542 bytes, 0 underruns
Port Mode Encapsulation Status Native vlan
Gi1/0/40 on 802.1q trunking 1
Gi1/0/40 1-4094
Gi1/0/40 1-2,29,123
Gi1/0/40 29,123
Amy help would be greatfully recieved
02-23-2012 05:04 AM
This switch is out of the box config
02-23-2012 10:38 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Does the 2960 have a management IP assigned? If if does, do both switches share an IP on the same subnet? If not, is routing configured, and L2 switches have gateway addresses?
If the prior questions don't make sense, more information would be required to help you, and some of it might be even more complex when dealing the the 3560's configuration, as the latter can do L3. (As also can the 2960-S, although only with recent code and many limitations.)
02-25-2012 04:10 AM
hi marco,
how did u go with this? did u get a chance to look at this or have u fixed it?
Regard, Kishore
02-23-2012 03:47 PM
Hi ,
Few things.
1. As Joe pointed out. have you configured a a mgmt SVI on the 2960 switch.
2. Have you confuigured the default gateway on the 2960 pointing to a vlan on the 2560 stack.
Essentially, the config should be as follows.
3560
vlan199
name MGMT
int vlan 199
ip address 192.168.1.254 255.255.255.0
2960:
vlan 199
name MGMT
int vlan 199
ip default-gateway 192.168.1.254
Put the above configs on the switches and then ping from the 3560 to 192.168.1.1
Kishore
02-25-2012 01:59 PM
The problem is that the VLANs between the 2 switches do not match on both ends of switch interconnect.
02-27-2012 06:08 AM
Fergus,
When you say "switch interconnect" do you mean trunk port as ive checked the vlan and its set to "Trunk" or am i barking up the wrong tree. Can i also assign a VLAN to those ports even though they are trunking?
Joseph,
No management IP has been setup on it. Let me know what information you need and i can provide. They are on the same subnet of /23 and have the same gateway setup
Kishore,
I have tried this before and it doesnt work
Marco
