Stanby Cold Issue 7609
maumand
I have a 7609 that has one of the processor cards stuck in a Standby cold state, this became an issue when we removed and re-added syslogging the other day. Both SUP Modules are running the same version of code which is 12.2(33)SRB5, looking for some advice on how to repair this and get my redundant SUP card back into a Stanby Hot state.
Giuseppe Larosa
Hello Michael,
you can try to reload the standy processor
using
redundancy reload ?
  peer   Reload peer unit
  shelf  Reload this entire shelf
redundancy reload peer
Also be aware that other modules present in the chassis can play a role.
If I remember correctly there is a bug relative to the presence of a NAM service module in the chassis that can cause this.
Hope to help
Giuseppe
maumand
Thanks I will try that off hours this evening.
