Webcast-Catalyst9k
standard ip ACL
I try to use below commands to check stardard ip ACL
R3(config)#ip access-list standard cisco123
R3(config-std-nacl)#1 permit 1.1.1.0 0.0.0.255
R3(config-std-nacl)#2 deny 2.2.2.0 0.0.0.255
R3(config-std-nacl)#3 permit any
R3(config-std-nacl)#4 deny any
R3(config-std-nacl)#5 permit host 1.1.1.1
R3(config-std-nacl)#6 deny host 2.2.2.2
R3(config-std-nacl)#7 permit 1.1.1.2
R3(config-std-nacl)#8 deny host 2.2.2.3
R3(config-std-nacl)#9 permit host 2.2.3.5
R3(config-std-nacl)#10 deny host 2.2.3.6
R3(config-std-nacl)#11 permit 3.3.3.0 0.0.0.255
But I find the order of the rules is abnormal.
R3(config-std-nacl)#do sh access-list cisco123
Standard IP access list cisco123
    5 permit 1.1.1.1
    6 deny   2.2.2.2
    8 deny   2.2.2.3
    7 permit 1.1.1.2
    10 deny   2.2.3.6
    9 permit 2.2.3.5
    1 permit 1.1.1.0, wildcard bits 0.0.0.255
    2 deny   2.2.2.0, wildcard bits 0.0.0.255
    3 permit any
    4 deny   any
    11 permit 3.3.3.0, wildcard bits 0.0.0.255
According to the output, entries defined by host have high priority than those defined by prefix/mask and any. Those entries defined by host is also disordered(5,6,8,7,10). How do ACL entries order the entries?
BTW,If no entries defined by host the order is normal in standard ip ACL.
Thanks a lot
Martin
1 REPLY
Hall of Fame Super Gold
Re: standard ip ACL
You must order the entries yourself according to the logic, and that is key for the ACL to work as intended.
I don't know why the output is re-ordered, and I would not care about, altough it's a valid question.
300
