Webcast-Catalyst9k
Static Default route redistribution via route map fails in EIGRP
I am attempting to redistribute a default route into my eigrp process via a route map and acl, but the route is not being injected into EIGRP. I'm using the following commands, and I see the static in the routing table, as well as matching against the acl. Any thoughts on why this is not working?
router eigrp 1
redistribute static route-map redistribute-statics-eigrp
passive-interface default
no passive-interface Vlanxx
no passive-interface Vlanyy
network 1.1.1.0 0.0.0.255
network 2.2.2.0 0.0.0.255
auto-summary
route-map redistribute-statics-eigrp permit 10
match ip address 20
access-list 20 permit 0.0.0.0
ip route 0.0.0.0 0.0.0.0 null 0
-Scott
Re: Static Default route redistribution via route map fails in E
To clarify, I see the static default route in the routing table on the local router, but I do not see the default route in the routing table of any eigrp neigbor routers.
Hall of Fame Super Bronze
Your:
Change it to:
redistribute static route-map redistribute-statics-eigrp metric 1 1 1 1 1
(1 1 1 1 1) are arbitrary numbers (bandwidth, delay, reliability, load and MTU).
Also, disable auto-sumary with no auto-summary
263
