Static NAT to a range tcp ports
I want to map a range of tcp ports to an internal host from the internet. I could use the ip nat inside static tcp command for mapping an specific port, but what if I want to map the tcp port range from 8000 to 8050?, Is there a way to do that with a single command?
1 ACCEPTED SOLUTION
Silver
Re: Static NAT to a range tcp ports
Try this:
1.create static translation:
ip nat inside source static 192.168.60.10 172.16.181.195 route-map MAP extendable
ip nat inside source static tcp 192.168.1.2 80 172.17.181.195 80 extendable
2. Define the port range
access-list 101 permit tcp host 192.168.60.10 range 8000 8050 any
route-map MAP permit 10
match ip address 101
Refer the following link to Mapping an Application with a Port Range:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_configuration_guide_chapter09186a00800d981c.html#xtocid2671616
Silver
Try this:
Sorry for the Double post
I'm not quite following the address scheme here. I am attemting the same 10000 ports to one nat command, I have 192.168.1.0/24 as my inside addresses and the internet via DHCP as outside address. eth0/0 is internet (DHCP) eth0/1 is private NAT (192.168.1.0/24) I want to forward two ranges 5004-5082 udp and 10000-20000 udp to inside host 192.168.1.103. Can you give me a few pointers?
Thanks.
in your case, it would be like this:
ip nat inside source static 192.168.1.103 interface ethernet0/0 route map MAP
access-list 101 permit udp host 192.168.1.103 range 5004 5082 any
access-list 101 permit udp host 192.168.1.103 range 10000 20000 any
My Cisco 2611 is not accepting the command. It won't allow anything after "ethernet0/0". it is expecting the end of the line after ethernet0/0.
Any suggestions?
Your command would go like
Cheers !
I tried
ip nat inside source route-map MAP interface ethernet0/0
with no results I also finished by adding the other configs). I'm still lost and not working.
486
