Static port forward range
Is it possible to forward a range of ports when using the following command:
ip nat inside source static tcp <ip> <port> <ip> <port>
The only way I can think of is to use a route-map command, but I can seem to get this working.
Andrew
p.s. I do not wish to use an IP to IP tatic map, I need to specify individual ports
Re: Static port forward range
will u clear it in more detail, what u want exactly?
To forward ports 5000 to 5200 to an internal IP, without:
A) Putting 200 static entries into my config
B) Mapping a public IP to a private IP
193
