static route ll work?
hi friends,
i am having tunnel between dubaicenteral to spain and its working fine and also i am having tunnel between dubaicenteral to dubai remote site.
my question is if i add a static route in the dubai remote side i can able to access on spain network?.if its not possible tell me the way how i can connect.
thanks
Hall of Fame Super Gold
Re: static route ll work?
Yes, it is possible.
Recommend that you avoid static routes, use a routing protocol instead.
i can use ospf or rip protocol
i need to mention the networks in the routing protocols
is it correct.
It is.
However if you do not have experience or certification in networking, recommend you consult a professional for best results.
hi,
can you explain me
just i need to know the concept.
118
