static route to /13 subnet or eigrp route to /24 subnet,
Hopefully someone can clarify this point. The best path to a network will be a EIGRP learned, more specific route (/24), or a static route to a least specific network ( /13).
I thought it was the more specify match...but am not sure. I cannot see the static routes in the routing table or as feasible sucesssors in the topology table......I would appreciate some advice.
Re: static route to /13 subnet or eigrp route to /24 subnet,
Both routes will appear in the routing table, but the more specific route will always win for destinations within that /24.
If the static route is not appearing in the routing table, check the next hop address for a typo. There must be a valid routing table entry to get to the next hop address - either connected or learned.
Foeh
Silver
In your case the longest match will win. THe longest match is /24. This is because the administrative distance for a routing protocol is not used unless two routes are matched. That is if you have a static /24 and EIGRP /24 to the same subnet the router will use the lower administrative distance which is the static. In your case it is different,
Please rate if the post helped you,
110
