Static Routing with timers
Hi all,
We are using DXX as a primary link and I-Direct as secondary link between our Head Office and a branch office in other city. We are using static routing for automatic switching between the links i.e. when DXX goes down I-Direct comes up automatically. These days our DXX is fluctuating. This creates alot of trouble. Is there any thing as a timer on static routes that if our DXX is down and I-Direct is working and suddenly DXX comes up so I-Direct should wait for a certain hold down time before switching back to DXX.
Thanks in advance.
- Jay
Silver
Re: Static Routing with timers
which type of interfaces do you have?
In general, you can use a 'backup interface' command with a specific 'backup delay'.
Example:
backup delay 10 30 ! 30 is your 'hold down time
backup interface
Remember: it's important that on during the fault the encapsulation goes down to use correctly the backup interface
Andrea
Thanks alot Andrea, your sugesstion solved my problem. You are the best.
Reagrds,
Jay
Silver
you're welcome, Jay.
Best Regards
Andrea
You could also consider interface dampening.
if a port flaps few times, it is penalised and shutdown until it stablises.
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t13/feature/guide/ftipevdp.html
Sam
109
