07-26-2006 12:48 AM - edited 03-03-2019 01:27 PM
I'm trying to configure following command for Multicast traffic control on FE interface of CAT6500 with IOS version :12.1(26)E1 , Sup2/MSFC2.
I'm getting following error.
MLS-88-2(config-if)#storm-control multicast level 1
Command Rejected: Multicast suppression is not supported on Fa3/6
Can any one help on this ?
Chintan
07-26-2006 01:26 AM
Please check the Cisco doc. as below that only part of the GE support multicast storm control.
i.e.If you are using FE interface, it can't support.
Hope this helps.
07-26-2006 11:44 PM
hi,
Thanks. So Whether Sup1/Sup2 , MSFC2 will not support Multicast strom control on FE interface ?
Rgds
Chintan
