STP Bpdu filter
feroz syed
Level 3
Level 3
i have some confusion with Bpdu filter, when we configure bpdu filter  on seperate portfast enabled port it will filter outgoing bpdu and incoming bpdu (no stp).
If we we configure bpdu filter gobally it enable portfast feature on all port with bpdu filter, if any port receive bpdu message the port lose both filter and portfast state and act like normal stp port
Please correct me if am wrong.
2 Accepted Solutions
mudasir05
Hello Feroz,
so far as my understanding goes ur absolutely right.
BPDUfilter when enabled on an interface just filters BPDUs in both directions, which effectively disables STP on the port.Bpdu filter will prevent inbound and outbound bpdu but will remove portfast state on a port if a bpdu is received.Enabling BPDU filtering on an interface is the same as disabling spanning tree on it and can result in spanning-tree loops.
when (spanning-tree portfast bpdu-filter default) enabled Globally , an STP port enabled with portfast is not assumed to recieve BPDUs, However, if for any reason the port recieves BPDUs, the Port shall go into (Blocking , listening , learning and then Forwarding state ) and the port will be subject to noramal STP calculations whether being in forwarding or blocking state.
dragos_sony
hope it helps
https://supportforums.cisco.com/document/45136/importance-bpdu-guard-and-bpdu-filter
mudasir05
Hello Feroz,
dragos_sony
hope it helps
