You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our beta test area to get started.
STP BPDU Kills CPU on Cisco 7609
Cisco 7600 is connected with routed port on OSM module to a switch. Network behind the switch experiences L2 loop and STP goes crazy. This kills CPU on Cisco 7600. I would like to know is there a mechanism to prevent this behavior. How does Cisco 7600 treat STP BPDU that comes in on a routed port?
  • WAN Routing and Switching
Hall of Fame Super Silver
Re: STP BPDU Kills CPU on Cisco 7609
Hello Davor,
on a routed port STP BPDUs should be ignored.
But in your case the C7600 cpu goes high and STP is among the processes using more cpu if I understood correctly your post.
I suppose you have checked this with
sh proc cpu sorted
During the L2 loop there are also an high level of broadcast frames ?
Hope to help
Giuseppe
Well, I didn't have access to the box at the time of problem. All I could see was output from #sh proc cpu history and the fact that all routing protocol adjacencies were broken at that time. I'm not 100% sure what happened but I know that there was stp loop on that side. I wouldn't count that there were a lot of broadcast frames because there is only one other host on this Vlan.
280
