strange behavior on 7206 with cef
hi,
i have a 7206 router on which i HAD a interface gig0/2.2178 with an ip-adr 10.20.255.225 255.255.255.248 !
i then deleted the interface 0/2.2178
(no int ..) and configured this interface on an other router which has a ospf-connectivity tzo the 7206.
the 7206 learned the net 10.20.255.224/29
from the new router - ok
mplsrbgope01#sh ip rou 10.20.255.225
Routing entry for 10.20.255.224/29
Known via "ospf 65052", distance 110, metric 146, type inter area
Last update from 172.16.24.86 on GigabitEthernet0/2.190, 00:07:55 ago
Routing Descriptor Blocks:
* 172.16.24.86, from 172.16.24.20, 00:07:55 ago, via GigabitEthernet0/2.190
Route metric is 146, traffic share count is 1
mplsrbgope01#sh ip rou 10.20.255.227
Last update from 172.16.24.86 on GigabitEthernet0/2.190, 00:07:58 ago
* 172.16.24.86, from 172.16.24.20, 00:07:58 ago, via GigabitEthernet0/2.190
BUT:
When i tried to ping 10.20.255.225 and .227 - i have different resaults.
.225 is ok and .227 is nok
then i saw the cef tabele from the 7206:
mplsrbgope01#sh ip cef 10.20.255.225
10.20.255.224/29, version 85589, epoch 0, cached adjacency 172.16.24.86
0 packets, 0 bytes
Flow: AS 0, mask 29
tag information set
local tag: 1406
via 172.16.24.86, GigabitEthernet0/2.190, 0 dependencies
next hop 172.16.24.86, GigabitEthernet0/2.190
valid cached adjacency
tag rewrite with Gi0/2.190, 172.16.24.86, tags imposed: {}
mplsrbgope01#
mplsrbgope01#
mplsrbgope01#sh ip cef 10.20.255.227
10.20.255.227/32, version 85586, epoch 0, connected, cached adjacency 10.20.255.227
0 packets, 0 bytes
Flow: AS 0, mask 29
via 10.20.255.227, GigabitEthernet0/2.2178(deleted), 0 dependencies
next hop 10.20.255.227, GigabitEthernet0/2.2178(deleted)
invalid cached adjacency
mplsrbgope01#
strange - .227 looks like it is on the deleted interface - .225 (which is the int adr. of the new router is ok)
so it seems the 7206 looks for .227 in the deleted interface - althoug the routingtable is ok.
i also found no command to clear the one entry in the cef - it is a corerouter so i cannot do a "clear ip cef *"
any idea ???
thanks
137
