Strange behaviour on a 7304 with SNMP via VRF
HI all,
The thing is when I configure this router to send snmp traps to a host with the command "snmp-server host 10.0.0.1 community" it works properly but if you try to send traps via a VRF with the command "snmp-server host 10.0.0.1 vrf VPN_A community" router shows a very strange behaviour. There is a switch attached to this router and after put this command you lost half of the packets sended to the switch from a pc, any idea?
Thanks in advance.
Bronze
Re: Strange behaviour on a 7304 with SNMP via VRF
SNMP Support for VPNs allows users to configure an SNMP agent to only accept SNMP requests from a certain set of VPNs. Check out the following link for more info :
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a00804557c4.html
Thanks for the link, We´ve figure out it is not supported in the 7304 router, but seems strange because in one box works properly while not in other one (both 7304)...
121
