Strange Error Message
One of my customers has a 3845 router with 12.3 ISP IOS that has been up for 20 plus weeks.
Got a bunch of the following messages and there is nothing on the web to indicate what they mean.
Here is the error:
bad token 0, wanted TOK_NUMBER|TOK_PUNCT
Any Ideas? Thanks.
jackyoung
Level 6
Level 6
Checked in Google, it looks like the lanaguage code or JAVA or C++. I suspect there may be some issue in the IOS and cause this error but should not display in the log.... Try to open a TAC case to investigate it w/ Cisco.
Hope this helps.
smothuku
Level 7
Level 7
Hi ,
Can you check whether is there any tarce back or %SYS-3-CPUHOG: messages in the output of sh log...
Is it possible to paste the show-tech of the router ..
while searching for known issues I've found one bug CSCdw53063(old one) where I've seen the follwoing messages.
Jan 11 10:49:35 [192.168.1.2.227.34] 396: *Mar 9 23:43:05.542: bad token 0, wanted TOK_NUMBER|TOK_PUNCT
Jan 11 12:41:24 [192.168.1.2.227.34] 398: *Mar 10 01:34:54.410: bad token 0, wanted TOK_NUMBER|TOK_PUNCT
Jan 11 14:31:14 [192.168.1.2.227.34] 399: *Mar 10 03:24:44.477: bad token 0, wanted TOK_NUMBER|TOK_PUNCT
Jan 11 16:37:05 [192.168.1.2.227.34] 400: *Mar 10 05:30:35.245: %SEC-6-IPACCESSLOGP: list 121 denied tcp 195.14.144.55(2300) -> 0.0.0.0(23), 1 packet
Jan 11 16:57:54 [192.168.1.2.227.34] 401: *Mar 10 05:51:24.376: %SYS-3-CPUHOG: Task ran for 2016 msec (572/352), process = Virtual Exec, PC = 602B3CD0.
Jan 11 16:57:54 [192.168.1.2.227.34] 402: -Traceback= 602B3CD8 60218040 602189CC 60218414 609FC8E8 609E6C3C 602336C4 602412B4 6029CB14 6029CB00
So it is better check whether you are getting same kind of messages.
Satish
