Strange OSPF behavior in redistribution
dear all,
I have an issue with 7206 router running OSPF. when I redistribute BGP with route-map into OSPF It takes roughly 24 hours to install the BGP routes into OSPF database.
route-map contains only a match statement that matches a standard access-list.
does anyone know what causes this issue?
thanks
Re: Strange OSPF behavior in redistribution
How many entries are in the BGP table and BGP routes in the route table.
peter
Bronze
Hi.
Can you check any memorty related issue in router , also check logs of the router, any suspicies found in that?
Please send me configuration and IOS version ..
this will might help you out...
-Minu
hi all,
there are 61 bgp routes in the routing table.
5 minutes process cpu is 5%
memory is less than 50%
config as below
router ospf 280
log-adjacency-changes
redistribute static metric-type 1 subnets route-map STATIC-to-OSPF
redistribute bgp 65512 subnets route-map BGPOSPF
passive-interface default
no passive-interface FastEthernet0/0
no passive-interface FastEthernet2/1
network x.x.x.x 0.0.0.255 area 0
route-map BGPOSPF permit 20
match ip address 50
Bronze
clear ip ro * mate its a "feature" ive seen this before
268
