strange ospf router id
I have a 6500 running 12.1(23)E2 and I'm getting strange results with OSPF ids. I have not explicitly set the router ID, and do have a loopback configured with ospf. The strange thing is that it seems to be using an IP address for its router ID that isn't even configured on the router anywhere, and in fact is the HSRP virtual IP address of a different pair of routers.
I've tried resetting OSPF to no avail.
I'm stumped! Any ideas would be greatly appreciated.
thanks,
Peter
Re: strange ospf router id
The RID it is using might be an address that was configured in the box earlier and subsequently removed. If possible, remove the OSPF config completely, reload and put it back on. If it still continues to pick up that address RID from nowhere, do a bug search on CCO for the 12.1(23)E2 code.
Pls. rate all helpful posts.
HTH,
Sundar
An alternative way to completely reset the ospf process without reloading the box is to use the following procedure:
save your running config. (copy runn start)
remove the ospf process (no router ospf xx)
reconfigure the ospf process (config mem)
Hope this helps,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222 Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
What I actually ended up doing was:
router ospf
router-id x.x.x.x
router bgp
bgp router-id
I then cleared the ospf process and bgp
was taken care of automagically.
This seems a lower impact than either rebooting
or removing the routing processes. I never stated
this, but this was a production router.
thanks,
peter
86
