Strange ping output
Hi Friends,
While doing an extended ping, i found a strange ping output and not sure what exactly it means (QQQQQ). Kindly advice if anyone of you have come across such thing earlier. Thanks in advance
Router#ping ip
Target IP address: A.B.C.D
Repeat count [5]: 1000
Datagram size [100]: 1000
Timeout in seconds [2]:
Extended commands [n]:
Sweep range of sizes [n]:
Sending 1000, 1000-byte ICMP Echos to 10.192.148.132, timeout is 2 seconds:
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!QQQQQQQQQQQQQQQQQQQQQQQQQ
QQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQ
Success rate is 25 percent (254/1000), round-trip min/avg/max = 8/22/80 ms
Router#
Hall of Fame Super Gold
Re: Strange ping output
Q is source quench, very rate to get, check what router is sending that.
Yes, as Paolo already said, this Q denotes a Source Quench (http://en.wikipedia.org/wiki/ICMP_Source_Quench) in Cisco routers. The ping output you posted is from a router and routers normally rate limit their outgoing ping packets (1 ping packet every second or something like that and you cannot change this behavior as far as I know), so I would not consider the particular router ping (even with 1000 packets of 1000 bytes each) being solely responsible for the Quench. Perhaps you ping an already "tired" destination (from other sources besides your ping).
Kind Regards,
M.
ICMPv4 Source Quench messages are sent by a device to request that another reduce the rate at which it is sending datagrams. They are a rather crude method of flow control compared to more capable mechanisms such as that provided by TCP.
Check the cisco link below.
http://www.cisco.com/warp/public/63/ping_traceroute.html
What's interesting about the Source Quench format is that it is basically a “null message”. It tells the source that the destination is congested but provides no specific information about that situation, nor does it specify what exactly the destination wants the source to do, other than to cut back on its transmission rate in some way. There is also no method for the destination to signal a source it has “quenched” that it is no longer congested and to resume its prior sending rate. This means the response to a Source Quench is left up to the device that receives it. Usually, a device will cut back its transmission rate until it no longer receives the messages any more, and then may try to slowly increase the rate again.
In a similar manner, there are no rules about when and how a device generates Source Quench messages in the first place. A common convention is that one message is generated for each dropped datagram. However, more intelligent algorithms may be employed, specially on higher-end routers, to predict when the device's buffer will be filled and preemptively quench certain sources that are sending too quickly. Devices may also decide whether to quench all sources when they become busy, or only certain ones. As with other ICMP error messages, a device cannot count on a Source Quench being sent when one of its datagrams is discarded by a busy device.
The lack of information communicated in Source Quench messages makes them a rather crude tool for managing congestion. In general terms, the process of regulating the sending of messages between two devices is called flow control, and is usually a function of the transport layer. The Transmission Control Protocol (TCP) actually has a flow control mechanism that is far superior to the use of ICMP Source Quench messages.
Another issue with Source Quench messages is that they can be abused. Transmission of these messages by a malicious user can cause a host to be slowed down when there is no valid reason. This security issue, combined with the superiority of the TCP method for flow control, has caused Source Quench messages to largely fall out of favor.
thats intresting.
Can u please see the below. It seems with smaller byte count, its fine, however as the byte count increases, then the QQQQ output increases too. However, ping to other servers on the same LAN seems to be working perfectly fine. So this seems to be more like a particular server issue rather than a router issue. Is that right.
Router#ping ip
Target IP address: 10.192.148.132
Repeat count [5]: 400
Datagram size [100]: 500
Extended commands [n]: y
Source address or interface: 10.222.68.14
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sending 400, 500-byte ICMP Echos to 10.192.148.132, timeout is 2 seconds:
Packet sent with a source address of 10.222.68.14
Success rate is 100 percent (400/400), round-trip min/avg/max = 1/1/4 ms
Router#ping ip
Repeat count [5]: 500
Sending 500, 500-byte ICMP Echos to 10.192.148.132, timeout is 2 seconds:
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!Q
QQQQQQQQQQ
Success rate is 97 percent (489/500), round-trip min/avg/max = 1/1/4 ms
Router#ping ip
Repeat count [5]: 600
Sending 600, 500-byte ICMP Echos to 10.192.148.132, timeout is 2 seconds:
Success rate is 81 percent (490/600), round-trip min/avg/max = 1/1/4 ms
Router#
Manoj
Hall of Fame Super Silver
so your destination is a server NIC and not a router interface ?
other servers can be pinged correctly with any size/number of packets on the same LAN.
This might be the result of some form of ICMP rate limiting where instead of simply dropping packets exceeding the rate limit the server sends back source quench.
It could be a form of protection from ICMP attacks.
Interesting issue
best regards
Giuseppe
Blue
Giuseppe is right.
Whichever device is sending the source quench, it is interpreting your excessive PINGs as a possible DoS attack.
Victor
1078
