Community Member
Stratacom - IGX - Questions regarding connections and trunks paths
Is there any command that will show which ports/lines are being used for a connection and/or trunk?
I?m aware that when using the command ?dspcon x.x.y.y? it will indicate the trunks being used, yet no information is displayed indicating which physical lines or ports are transversed.
1 REPLY
Silver
Re: Stratacom - IGX - Questions regarding connections and trunks
dsplnerrs checks the line alarm status and reports the number of major or minor errors and any disabled lines.Refer URL
http://www.cisco.com/en/US/products/sw/ps2346/ps99/products_tech_note09186a0080093bd7.shtml
111
