01-28-2014 02:09 PM - edited 03-04-2019 10:11 PM
Routers 1 - 8 are running IS-IS and they are tag-switching. I can reach all routers loopbacks within the core network.
Now I am peering eBGP with R4 and R7 and I have R4 and R7 peering iBGP. Now from R4 and R7 I can see routes from end to end, but R12 and R9 cannot see each others routes/networks.
I need to redistribute these from R4 and R7 so that R9 and R12 can see them....How can I do this without those routers seeing all the subnets and routes in the core of the network?
Solved! Go to Solution.
01-28-2014 03:01 PM
R9#wr
Building configuration...
[OK]
R9#show ip bgp 192.168.12.0 255.255.255.0
BGP routing table entry for 192.168.12.0/24, version 12
Paths: (1 available, best #1, table Default-IP-Routing-Table)
Not advertised to any peer
65000 64712
172.16.9.2 from 172.16.9.2 (10.10.10.4)
Origin incomplete, localpref 100, valid, external, best
R9#show ip route 192.168.12.0
Routing entry for 192.168.12.0/24
Known via "bgp 64709", distance 20, metric 0
Tag 65000, type external
Last update from 172.16.9.2 00:11:45 ago
Routing Descriptor Blocks:
* 172.16.9.2, from 172.16.9.2, 00:11:45 ago
Route metric is 0, traffic share count is 1
AS Hops 2
Route tag 65000
R9#
01-28-2014 03:05 PM
Steven
Check the IP routing table on R12 and pick a network advertised from R9. Then from R9 ping 192.168.12.1 with the source IP from the network R12 has an entry for in it's routing table.
Jon
01-28-2014 03:18 PM
Steven
Apologies but i should have said you need to redistribute BGP into IS-IS but not the other way round. This is because the intermediate routers between R4 and R7 need to know about the networks on R9 and R12.
The alternative is to run a full IBGP mesh between every router within your AS or use route reflectors.
Once again sorry i made the same stupid mistake in another thread recently.
Edit - by redistributing BGP into IS-IS you could actually leave synchronization on but you would still have needed to fix the next-hop self issue.
Jon
01-29-2014 08:53 AM
Ok so my logical thinking of having to redistro BGP into ISIS was correct. I wonder if ISPs are running full BGP mesh in the mpls cloud...
01-29-2014 09:24 AM
Steven
Yes, my mistake.
In terms of MPLS it works slightly differently. So with your setup the external routes eg. 192.168.12.0/24 have to redistributed into the IGP. Then when R4 receives a packet for 192.168.12.x it looks up the next hop and sees it is R7 and to go get to R7 it needs to send the packet to R1.
R1 on receiving the packet does a route lookup for 192.168.12.x and sends it to R3 (probably ie. it could via the R2 to R3 link depending on metrics etc). and so on. So each internal router does a route lookup on the destination IP.
MPLS does not work like this. The PE devices (R4/R7) exchange routing information for external networks, VPN information etc using IBGP or more specifically MP-IBGP. An IGP is run within the MPLS network so that all PE devices and P devices (eg. R11/2/3) can exchange routes and together with label exchanges an MPLS forwarding table is built on each device.
Note that the EBGP learnt routes on the PE devices are not redistributed into the IGP.
So each PE device in terms of finding the next hop for a destination IP external to the MPLS network uses the same procedure as with R4/R7 as in your setup. The PE device then looks in it's MPLS forwarding table to see how to get the egress PE device and sees it needs to send it to the next hop P device (P devices in your network would be R1/R2/R3).
It then adds an MPLS label to the header of the packet and sends it to the first P device. This P devices simply extracts the label, sees the incoming label value, looks in it's MPLS forwarding table and finds an entry that says a label received on this interface with this value should be sent out of the interface connected to the next P device with a specific value. So it simply adds a new label with the new value and sends it on to the next P device etc.
At no point does any P device actually do a route lookup for the destination IP. In fact they don't even look into the IP header for that information, they simply use labels. So that is why you do not need to redistribute PE EBGP learned routes into the IGP.
The above is a brief description as to how MPLS works. Obviously it hasn't really covered VPNs, how the MPLS forwarding table is built, certain features such as PHP (Penultimate Hop Popping) etc.
I didn't want to confuse the main point but if you need clarification please ask.
Jon
01-29-2014 10:28 AM
So how do I know if I am running MPLS in my core correctly? You mentioned a MPLS routing table? How do I see that?
01-29-2014 10:38 AM
Steven
If you are running MPLS in your setup then you do not redistribute the EBGP routes into your IGP. So assuming you don't redistribute and you cannot ping from an external network on one side to an external network on the other side using the correct IP as a source IP then your MPLS setup is not working properly.
The command should be "sh mpls forwarding-table"
Depending on IOS version the actual command used to enable MPLS may be slightly different.
Edit - i missed the bit about tag switching your initial post so you are running MPLS.
Jon
01-29-2014 10:41 AM
I am trying to learn more about MPLS and how it works, so I went through this:
http://www.cisco.com/en/US/tech/tk436/tk428/technologies_configuration_example09186a0080093fcc.shtml
So it had me doing "tag-switcing ip" commands...I am not really sure what I have going on.
01-29-2014 10:51 AM
Steven
No problem. I am probably not helping as i missed the point about MPLS in your initial post so i have confused the issue.
Not one of my better posts.
So to recap. You do not need any redistribution either way if this is MPLS.
From that document you linked to it looks like you are using an older IOS (or document) as the commands have changed now ie. where you have "sh tag-switching forwarding table", most modern IOS versions use "sh mpls forwarding table". Some IOS versions allow you to use either.
Bear in mind you can use any IGP you are familiar with.
So have you run the commands in the verify section to of your link on all routers to see what is happening ?
Jon
01-29-2014 10:57 AM
I was just looking to get up an MPLS network in GNS3 fast to work on PE-CE peering, but I got pretty deep into ISIS and was enjoying it so I kept going. I am seeing reference to MPLS for commands like vpnv4 and looks a lot more VRF's involved. But no worries to you, your posts have had some good stuff that I wouldnt have known...like the next-hop-self command, I never really knew what that was for.
01-29-2014 11:01 AM
R1#show mpls forwarding-table
Local Outgoing Prefix Bytes tag Outgoing Next Hop
tag tag or VC or Tunnel Id switched interface
16 Untagged 10.10.10.4/32 195 Se0/0 point2point
17 Untagged 10.10.10.5/32 0 Se0/3 point2point
18 Pop tag 10.10.10.2/32 304 Se0/2 point2point
19 Pop tag 10.1.1.28/30 0 Se0/2 point2point
20 Pop tag 10.10.10.3/32 194 Se0/1 point2point
21 16 10.10.10.6/32 0 Se0/1 point2point
22 17 10.10.10.7/32 0 Se0/1 point2point
23 Pop tag 10.1.1.20/30 0 Se0/1 point2point
24 Pop tag 10.1.1.24/30 0 Se0/1 point2point
25 Pop tag 10.1.1.8/30 0 Se0/1 point2point
26 22 10.10.10.8/32 0 Se0/2 point2point
R1#
R7#show mpls forwarding-table
Tag switching is not operational.
CEF or tag switching has not been enabled.
R7#
R1#
Doesnt look R7 (PE) has anything??
R7#
01-29-2014 11:04 AM
Steven
You need to run this command on all MPLS routers and if it is not enabled then make sure it is.
Without all PE/P devices having forwarding tables end to end connectivity won't work.
Jon
01-29-2014 11:16 AM
Ok it was the "ip cef" was not configured on some other routers. But even now I do not see any info on the external 192.168. networks in this table? Also what does "Untagged" mean?
01-29-2014 11:20 AM
Steven
Untagged simply means the packet will not have a tag/label.
I thought you were seeing the routes on R4 and R7. If you mean you are not seeing them on the P devices (R1/R2/R3) then you shouldn't be because you are not redistributing from BGP and the P devices only need labels to forward the traffic.
But all MPLS routers ie. PE and P devices need MPLS forwarding tables.
So can you confirm where you are not seeing the external routes ?
Jon
01-29-2014 11:23 AM
Correct, I see the table in all P and PE routers, but PE's do not reflect 192.168.x.x addresses. No redistribution has been done since I do not want to do it that way.
16 Untagged 10.10.10.8/32 0 Se1/0 point2point
17 Untagged 10.1.1.8/30 0 Se1/0 point2point
18 Untagged 10.1.1.12/30 0 Se1/0 point2point
19 Untagged 10.10.10.2/32 0 Se1/0 point2point
20 Untagged 10.10.10.3/32 0 Se1/0 point2point
21 Untagged 10.1.1.0/30 0 Se1/0 point2point
22 Untagged 10.10.10.1/32 0 Se1/0 point2point
23 Untagged 10.10.10.6/32 0 Se1/0 point2point
24 Untagged 10.10.10.4/32 0 Se1/0 point2point
25 Untagged 10.1.1.4/30 0 Se1/0 point2point
26 Untagged 10.10.10.5/32 0 Se1/0 point2point
27 Untagged 10.1.1.28/30 0 Se1/0 point2point
28 Untagged 10.1.1.16/30 0 Se1/0 point2point
29 Untagged 10.1.1.20/30 0 Se1/0 point2point
