Stuck
OK Gang this is what I got going.
I have a connection from COX professional services.
(IP address are not real that I post)
I plugged in to F0/0 (this is not a T1)into my 2621 router.
ip 50.142.78.211
mask 255.255.255.224
gw 50.142.78.201
I set an ip route of 0.0.0.0 0.0.0.0 50.142.78.201
I plug my little linsys switch into F0/1 on the 2621 router
Gave int f0/1
ip 10.10.10.5
mask 255.255.255.0
Gave my workstation
ip 10.10.10.50
mask 255.255.255.0
gateway 10.10.10.5
I can ping external from the router but not my laptop plugged into the linsys switch.
I can ping int f0/1 from my laptop but nothing beyond that.
I also tried putting in a ip default-gateway of 50.142.78.201
Hall of Fame Super Silver
Re: Stuck
Joel
If your workstation has address 10.10.10.50 and is attempting to gain outside access you will need Network Address Translation. It is not clear from what you posted that you have configured NAT. Without NAT the outside will not have a route to your workstation.
Rick
Re: Stuck
No I have not configured NAT and never have. Any hints would be greatly appreciated.
Re: Stuck
Joel
The NAT configuration would look something like this:
interface fast0/0
ip nat outside
interface fast0/1
ip nat inside
access-list 50 permit 10.10.10.0 0.0.0.255
ip nat inside source list 50 interface fast0/0 overload
Rick
101
