07-27-2006 08:52 PM - edited 03-03-2019 01:28 PM
Dear All,
I am unable to delete sub interface on ethernet port of router ...
can somebody help..
regds,
Aman
Solved! Go to Solution.
07-27-2006 10:26 PM
Hi Aman,
Could u reload the router???? Becz i heard somewhere that until the router reload show ip interface brief command will show the subinterface as deleted only.
Once specific type of subinterface is created, it cannot be changed without a reload.When a subinterface is configured, an interface descriptor block (IDB) is defined by the Cisco IOS. IDBs defined for subinterfaces cannot be changed without a reload.
So if possible have a try by reloading the router,
Rate if it does,
Rgs,
07-27-2006 09:00 PM
the syntax to delete for example subif fa0/0.1 is:
no int fa0/0.1
Leo
07-27-2006 09:38 PM
Dear Leo,
We have tried this command but when we run show int description , it shows port as deleted ...
we want to permanently delete this sub interface .
regds,
Aman
07-27-2006 10:25 PM
There is nothing really difficult about deleting a subif. We might not be talkint the same thing here. Can you please post the output that you assume to be incorrect? A description of the commands that you use would be helpful too.
Leo
07-27-2006 10:32 PM
07-27-2006 10:58 PM
Please try to reload the router.
Leo
07-27-2006 10:26 PM
Hi Aman,
Rate if it does,
Rgs,
07-27-2006 11:17 PM
Thanks Balajit ...
I reloaded the router and sub interfaces were permanently removed .
regds,
Aman
