Suggested CCNP LAb for study purpose ?
Hi ,
Pardon me if this is the wrong location to place my question,
I need to suggest a CCNP lab for one of teh IT college that covers the whole 4 exams ?
Appreciate your kind support , any suggestions ? Thanks
Re: Suggested CCNP LAb for study purpose ?
Hi Saad,
   You can use Boson Network Simulator & Router Simulator for your CCNP Lab its very good Simulator for Lab purpose.
URL: http://www.boson.com/AboutNetSim.html
Hope this Helps.
Srinadh.
Saad,
I would recommend hands on real routers and switches rather than simulators or packet tracers !
Please check out some vendors like INE for the best !
Practicing the Cisco press book exercises on real gears will also help.
If you have real router then you can setup the lab & If you don't have the real router the  you can setup in GNS3 for emulate the CCNP LABS.
And  for CCNP LAB i suggest you to get an CCNP LAB workbook of Netmetric Solution . You will get in www.4shared.com or in any forum.
Chetan Kumar
http://chetanress.blogspot.com
194
