SUP WS-X4013+ with WS-C4507R-E (Does support EIGRP?)
Customer has WS-X4013+ supervisor engine and want to use as redundant SUP for WS-C4507R-E. Is it possible to configure EIGRP then? Please confirm if possible.
Note that customer already has WS-C4507R with SUP WS-X4013+ and has configured EIGRP.
Sumaiya
3 ACCEPTED SOLUTIONS
Hello Sumaiya,
Based on the document, the SUP-II engine will not be having the feature set of EIGRP starting 12.2(25)SG. I notice you are running 12.2(52)SG. Below is the link
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/ps5347/product_data_sheet09186a0080197424_ps4324_Products_Data_Sheet.html
Another switch you have has 12.2(20)EWA3 which has a feature set of EIGRP, but it not supported by Cisco anymore, AFAIK.
You may get the feature set if you downgrade your IOS 12.2(52)SG to something lesser than 12.2(25)SG, but unfortunately is not supported by Cisco (i.e you won't get any TAC help !)
Hope this helps,
Vivek.
Yes, incase of hardware failure, you would get a support based on the entitlement you have with cisco.
Hope your query has been answered. Please close the thread.
Hello Sumaiya,
Hope this helps,
Vivek.
Hi Vivek,
Thanks a lot for your support.
One thing I want to be confirmed -
If i copy the 12.2(20) IOS from my existing switch to that SUP [the sup having 12.2(52)], then it will support full eigrp. but i will not get Tech support for IOS but for other issues - i will get. Am i right?
Sumaiya
Yes Vivek. Thanks a lot.
458
