Community Member
sup32 and 6500 compatibility qtn.
Is the WS-SUP32-10GE-3B compatible with the older, non "E" versions of 6500 series switch?
1 REPLY
Re: sup32 and 6500 compatibility qtn.
Hi Friend,
Yes it will work fine but sup720 and sup32 require WS-C6K-9SLOT-FAN2 (High Speed Fan Tray). Each power supply in the chassis must be at least 2500 W
Ankur
*Pls rate all helpful post
110
