SUP720 or MSFC 's ROMMON ?
Hello again,
The new IOS 12.2(18)SXF4 that I like to upgrade is larger then the sup-bootflash capacity, so I need to have access to disk0:
question:
1. I need to upgrade the ROMMON but which one? the SUP320 or the MSFC ?
2. The command in the release note, attached below show:
# show rom-monitor slot 1 rp
( sp for the SUP720 )
My Cat6509 did not take the rp or sp, please see below.
Then if I went ahead with the upgrade command without rp ( or sp ), the DFC#1 got involved somehow?
I confused, please advise.
Leo
D000RTR02#sho rom-monitor slot 1 ?
| Output modifiers
<cr>
Region F1: INVALID
Region F2: INVALID
Currently running ROMMON from S (Gold) region
D000RTR02#sho rom-monitor slot 1 sp
% Invalid input detected at '^' marker.
D000RTR02#sho rom-monitor slot 1 rp
Region F1: INVALID
Region F2: INVALID
D000RTR02#upgrade rom-monitor slot 1 ?
file the name of the SREC file
invalidate set a rommon region to invalid
preference set rommon region boot preference
D000RTR02#$lot 1 file tftp://10.141.4.25/c6msfc3-rm2.srec.122-17r.S4
Copying tftp://10.141.4.25/c6msfc3-rm2.srec.122-17r.S4 onto bootflash of dfc#1
%Error opening tftp://10.141.4.25/c6msfc3-rm2.srec.122-17r.S4 (Timed out)Invalid
destination file path
Loading c6msfc3-rm2.srec.122-17r.S4 from 10.141.4.25 (via Port-channel34): !!!!!
[OK - 669827 bytes]
Region F1: INVALID
Region F2: INVALID
Release Notes
Upgrading the MSFC3 ROMMON
Note Before performing this procedure, you must download the new ROMMON image from Cisco.com. The download procedure is the same as downloading Catalyst operating system images.
Upgrade Procedure for Systems Running Cisco IOS on the Supervisor Engine and MSFC
To upgrade the ROMMON version on your MSFC3 in a system that is running Cisco IOS software on the Supervisor Engine 720 and on the MSFC3, perform these steps:
Step 1 Check the active ROMMON information:
Router# show rom-monitor slot 1 rp
Region F1:APPROVED, preferred
Region F2:INVALID
Currently running ROMMON from F1 region
Router#
The display indicates that the active ROMMON is running in region1.
Step 2 Program the new ROMMON image to the Flash device on the MSFC3:
Router# upgrade rom-monitor slot 1 rp file
tftp://dirt/tftpboot-users/c6msfc3_rm2.srec.122-14r.S9
ROMMON image upgrade in progress
Erasing flash
Programming flash
Verifying new image
ROMMON image upgrade complete
The card must be reset for this to take effect
Router#
Step 3 Check the new active ROMMON information:
Region F1:APPROVED
Region F2:FIRST_RUN, preferred
Router#
Step 4 Reload the system:
Router# reload
Proceed with reload? [confirm]
Step 5 After the system comes up, check the ROMMON information again:
Region F1:APPROVED
Region F2:APPROVED, preferred
Currently running ROMMON from F2 region
Router#
1 REPLY
Silver
Re: SUP720 or MSFC 's ROMMON ?
864
