SUP720 to RSP720 upgrade
I am planning to upgrade from SUP720 to RSP720. I was looking for a step-by-step upgrade procedure document on CCO, no luck yet!
Just wondering if there is any relevant document available for this!
thanks,
Fawad
1 REPLY
Re: SUP720 to RSP720 upgrade
The following link will help you to see if RSP-720 supports your current hw:
http://www.cisco.com/en/US/docs/routers/7600/Hardware/12.2SR_supported_hw/7600_hwd.html#wp1031424
12.2(33)SRB minimum is required.
As a migration procedure assuming all the hw is supported, you should upload the target IOS in the flash in addition to the target configuration (including a no shut for the interface if you want).
Once it loaded, just copy the configuration from the flash to the running-config and do all the post-migration checking.
Laurent.
799
