Community Member
supervisor replacement cisco catalyst 6500 Switch
Hi gentleman
I have this cisco catalyst 6500 Switch series 9 - slot it has a long history of supervisor fail down and errors so we will replacement by now supervisor .
Are there any steps to flow replacement supervisor and are there any commands to run it before replacement and remover the old one .
Thank you gentleman
I really appreciate help
Community Member
Re: supervisor replacement cisco catalyst 6500 Switch
There is still a lot of information needed before anyone can answer your question.
First, what supervisor are you running now?  Sup 1a, Sup 2, Sup 32, or Sup 720?
Are you running redundant supervisors?
Are you replacing the current supervisor with the same type, or are you upgrading to a VSS or Sup 720?
Are you running in hybrid mode (Cat-OS and IOS), or are you running in Native (IOS only)?
If you are upgrading from a sup2 or older, you may have to reconfigure your blades to accomidate supervisor 720s (they have to go in slots 5 & 6).
With this information, we can provide more help on your request.
Rob
Community Member
hi geantlaman
ho are you buchholr
this is some answer you asked for
Cat 6k sup 1 Enhanced QoS            WS-X6K-SUP1A-2GE
no but I have redundant by used another switch
no by the same current supervisor
IOS and used Cat6k MSFC 2 daughterboard  WS-F6K-MSFC2 IOS
thank you
Community Member
Kindly refer to http://www.cisco.com/en/US/partner/products/hw/switches/ps700/products_tech_note09186a008015504b.shtml and locate the exact problem and share.
With regards
Shailesh
Community Member
hi shailesh.h
the linke does not work
Community Member
I attached document for your ready reference. I think this might required CCO login to visit this page..
With regards,
Shailesh
Community Member
Hi mates,
Let me take over from the last info provided.
I am about to replace a supervisor (RMA) but as long as I only have 1 chassis I wonder if you can advise me on how to do it safely.
The model is a WS-X6K-SUP2-2GE so slots 1 and 2 in a 6506 chassis.
In the old card I have a flash that contains the IOS so I will insert this into the new one but need to understand how I can safely boot it up without affecting the active.
boot system disk0:s222-ipservicesk9-mz.122-18.SXF10.bin
Directory of disk0:/
    1  -rw-    33523716   Aug 9 2007 04:49:38 +01:00  s222-ipservicesk9-mz.122-18.SXF10.bin
64233472 bytes total (30707712 bytes free)
Thanks in advance
Rgds
alex
2158
