Switch 3750
In new our project we want to use Switch 3750 series. our needs are 2 ports 10G (Fiber optic) and minimum 10 ports 1G (UTP) for this switch.
Which model from 3750 series do you suggest for this implementation?
Totally, How can I find correct prodcuts from cisco site for different needs?
Thanks in advance
VIP Super Bronze
Switch 3750
Hi Nima,
Since you need 2 10Gig ports, I recommend using a 3750X series switch.  Since you need 1Gig UDP ports, you can get a WS-C3750X-24T-S.  This will give you 24 10/100/1000 Copper ports and 2 10Gig fiber ports for your uplinks:
Have a look at the data sheet for more info:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/data_sheet_c78-584733.html
Reza
Super Bronze
Switch 3750
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Nima, if you don't anticipate (ever) needing the 3750's stacking feature, you might also consider the 3560 series.
Switch 3750
Thanks a lot for your quick reply
What differences are between 3750 and 3560 ?may you give me difference in a nutshell?
Thanks in advance
Super Bronze
Switch 3750
Disclaimer
Posting
The major difference between the 3650 and 3750 series is the latter supports stacking.  Otherwise they are generally identical although there's not always an exactly clone for every individual model between the two series when it comes to ports.
282
