06-27-2012 09:18 PM - edited 03-04-2019 04:49 PM
Hello Friends,
i have mistakenly erase 3750 flash drive now this is the current stte of the switch after booting:
please guide me step by step so i can troubleshoot the issue. Thanks
Faysal
Solved! Go to Solution.
06-27-2012 10:10 PM
ok, as long as ur ios is proper one its ok.
first set a new baud rate on ur switch to speed things up. then copy the IOS file into it.
Switch: set baud rate 115200
here you have to restart ur terminal and use the new baud rate to work with console, then initiate the copy process:
Swicth: copy xmodem: flash:[exact ios file name here]
when ur enter the command, you have to start file transfer (xmodem) from ur terminal application. its slow thou. after its complete remember to return the baud rate back to 9600 !
plz Rate if it helped,
Soroush.
06-27-2012 09:55 PM
do you have a backup IOS image?
here is step by step recovery:
http://www.cisco.com/en/US/products/hw/switches/ps628/products_tech_note09186a0080169696.shtml
if u had anymore questions, will be more than happy to help
Soroush.
06-27-2012 09:58 PM
yes I have but I don't want to install that i want to install the newer version which I alraedy have
06-27-2012 10:10 PM
Soroush.
06-27-2012 11:59 PM
bunldle of thnks it worked for me
