10-11-2010 10:19 PM - edited 03-04-2019 10:04 AM
following sw interface is not showing input/output flow of traffic.... any ideas....?
SW.ISBTHQ.ASW01#sh int gig 1/48
GigabitEthernet1/48 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet Port, address is 0022.55be.93ff (bia 0022.55be.93ff)
Description: *** GE-UTP -to- IIB103-SW01 (3750) GE-1/0/21 ***
Internet address is 10.16.101.226/30
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, link type is auto, media type is 10/100/1000-TX
input flow-control is off, output flow-control is off
Last input 00:00:00, output never, output hang never
Last clearing of "show interface" counters 2w0d
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 0 bits/sec, 0 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
L3 in Switched: ucast: 905001834 pkt, 111623242295 bytes - mcast: 0 pkt, 0 bytes
L3 out Switched: ucast: 1743853071 pkt, 2134521654058 bytes - mcast: 0 pkt, 0 bytes
905194180 packets input, 131248097797 bytes, 0 no buffer
Received 97466 broadcasts (0 IP multicasts)
1744345494 packets output, 2166340540041 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 lost carrier, 0 no carrier
10-12-2010 02:10 AM
I know that this is a silly question, but do you have traffic over that interface? Are the other counters increasing (L3 in/out, packet input / output)?
Cheers,
Calin
10-12-2010 02:27 AM
yes the interface is carrying traffic, i can see the traffic on the other node to which this interface is connected...
10-12-2010 04:03 AM
Can you tell us which platform and which IOS you are running? Is this the only interface that is showing a input/output rate of 0, and if so is the interface/vlan configuration somehow different from the other interfaces? There have been a few software defects like this in the past, particularly on the cat4000 series.
Tim
