Community Member
System returned to ROM by bus error - 7200-G2
When i was changing the class-maps i get lost the router. I have attached the crash log file, am i hitting a bug here? I have many times modified the class-maps on the go without any issues. Any suggestions and recommendations are highly appreciated.
cheers
Srinie
1 ACCEPTED SOLUTION
Re: System returned to ROM by bus error - 7200-G2
Here is the bug ID from the crash file:
CSCta32825 - http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCta32825
Fix is in 12.4(24)T3.
HTH,
jerry
Hall of Fame Super Gold
IOS Bug
HTH,
jerry
Community Member
Thanks mate
Hi Srini,
I would recomend to open TAC case - to decode tracebacks and find the DDTS you hit, or in case if it is a new one - do a thorough investigation.
Nik
496
