Community Member
T-1 Config Not Pinging
Hello Guys,
I have 2 routers with 2 T-1's connected with a crossover cable. I can't ping between routers. Why?
R1
controller t1 1/0
framing esf
linecoding b8zs
channel-group 0 timeslot 1-24
no shut
serial1/0/:0
ip address 10.30.1.1 255.255.255.0
no shut
R2
controller t1 1/0
framing esf
linecoding b8zs
no shut
serial1/0/:0
ip address 10.30.1.2 255.255.255.0
no shut
2 ACCEPTED SOLUTIONS
Re: T-1 Config Not Pinging
You need to make a T1 cable.
http://www.t-radtalk.com/howto/how_to_make_a_t1_cross_over.htm
Hope this helps.
NT
VIP Super Bronze
T1 cross over cables are different from regular cross over cables:
see the link for ping configuration:
VIP Super Bronze
Are you using T1 Cross over cable?
When you connect the cable, do you see link lights on the routers?
if yes, are the interfaces in up and up mode?
Reza
Community Member
I made a crossover cable using some cat 5 cable I had in my basement. When I plug up the I do not see any link lights come on. I long can the crover cable be? I think the one i have is 5 feet.
Hope this helps.
NT
VIP Super Bronze
Community Member
Thanks that was exactly what I needed. Everything works perfectly now.
259
