04-21-2006 01:22 PM - edited 03-03-2019 12:28 PM
we had a private PPP T-1 installed. one end of the circuit is a ds3 that is allocated out as seperate PPP T-1 on a 7204 b/c we have a VOIP phone system with many small branch offices. it looks like i have the ds3 controller and the serial interface configured correctly other than the fact the line protocol is down on the serial interface. on the other side we have a 3745. i have a t1 controller in slot 1 of the 3745 up - but i cant configure the interface.(config)#int s1/0
% Invalid input detected at '^' marker.
any ideas?
thanks in advance.
04-21-2006 01:45 PM
Can you post the output of "show ip interfaces brief" and "show controllers" for the T1?
What is in your config refering to the T1 controller?
Regards, Martin
04-21-2006 03:33 PM
T1 1/0 is the one i'm working on now. i couldnt sh all the output.
sh ip interface brief
Interface IP-Address OK? Method Status Prot
ocol
FastEthernet0/0 unassigned YES manual up up
FastEthernet0/0.10 172.16.1.1 YES manual up up
FastEthernet0/0.15 192.168.128.1 YES manual up up
Serial0/0 172.16.1.1 YES TFTP up up
FastEthernet0/1 10.10.11.254 YES NVRAM up up
Serial0/1 172.16.1.1 YES TFTP up up
Serial0/2 172.16.1.1 YES TFTP up up
Serial3/0:0 unassigned YES unset down down
Serial3/0:1 unassigned YES unset down down
Serial3/0:2 unassigned YES unset down down
Serial3/0:3 unassigned YES unset down down
Serial3/0:4 unassigned YES unset down down
Serial3/0:5 unassigned YES unset down down
Serial3/0:6 unassigned YES unset down down
Serial3/0:7 unassigned YES unset down down
Serial3/0:8 unassigned YES unset down down
Serial3/0:9 unassigned YES unset down down
Serial3/0:10 unassigned YES unset down down
Serial3/0:11 unassigned YES unset down down
Serial3/0:12 unassigned YES unset down down
Serial3/0:13 unassigned YES unset down down
Serial3/0:14 unassigned YES unset down down
Serial3/0:15 unassigned YES unset down down
Serial3/0:16 unassigned YES unset down down
Serial3/0:17 unassigned YES unset down down
Serial3/0:18 unassigned YES unset down down
Serial3/0:19 unassigned YES unset down down
Serial3/0:20 unassigned YES unset down down
Serial3/0:21 unassigned YES unset down down
Serial3/0:22 unassigned YES unset down down
Serial3/0:23 unassigned YES NVRAM up up
Serial4/0:0 172.16.1.1 YES TFTP up up
Serial4/1:0 172.16.1.1 YES TFTP up up
Serial4/2:0 172.16.1.1 YES TFTP up up
Serial4/3:0 10.0.0.22 YES NVRAM up up
sh controllers t1
T1 1/0 is up.
Applique type is Channelized T1
Cablelength is long gain36 0db
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20040713, FPGA: 15, spm_count = 0
Framing is ESF, Line Code is B8ZS, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (678 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
0 Line Code Violations, 2295 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 72458 Unavail Secs
04-23-2006 10:27 PM
Can you try this config and check whether you are getting interface serial 1/0:0 up ?
controller T1 1/0
no shut
framing esf
linecoding b8zs
clock source line
channel-group 0 timeslots 24 speed 64
Once you get the serial interface up in your config you can configure up the same using normal ip addres under it..
ip address 10.x.y.z 255.255.255.0
regds
04-24-2006 07:31 AM
(config-controller)#channel-group 0 timeslots 24 speed 64
%Timeslot 24 already used by other ds0-group
sh run ---->controller T1 1/0
shutdown
framing esf
linecode b8zs
ds0-group 1 timeslots 1-24 type e&m-wink-start
i cant get rid of the ds0-group cmd - thats why the interface is shut down. it says it still in use but its not.
04-24-2006 12:00 PM
Hi Jerry,
So what happens when you do the following:
conf t
controller t1 1/0
no ds0-group 1
Paresh
04-24-2006 12:26 PM
Jerry,
You should be able to remove the ds0-group command after shutting down the controller.
conf t
controller t1 1/0
shut
no ds0-group 1
Pls. rate all helpful posts.
Sundar
04-25-2006 08:34 AM
i tried to shut the interface and this is what i get.
(config-controller)#no ds0-group 1
Voice port(s) still in service
%This CAS group is not down, can not be changed
04-25-2006 02:00 PM
i had to disable the voice port that the ds0-group 1 command created then i could shut the controller and remove the ds0-group then add the proper channel-group command to the controller.
