07-05-2006 11:47 AM - edited 03-03-2019 01:14 PM
Hello all,
I will soon have the task of working on several routers at another company. The company has multiple sites connected by a variety of links. In particular, two sites are connected using a single T1 between a pair of 2611's. The company is interested in adding a second T1 for more bandwidth between the sites.
If a second T1 is added, what would the best way be to bundle the lines? I am planning on trying multilink ppp, or is there a better method?
Thanks!
Solved! Go to Solution.
07-05-2006 12:00 PM
Multilink PPP will give you true load balancing and is the only way to do it if a non cisco router is involved. The disadvantage is that you are adding the PPP overhead both to the packets and to the router processor. You may want to just do a simple load balance by packet option on the interfaces. It does not balance as well since packet size varies but it is very simple. If it does not work well you can alway go to the ppp solution.
07-05-2006 12:00 PM
07-05-2006 12:58 PM
As Tim said, MLPPP adds some overhead, BUT allows streams >T1 speed. We have both kinds of links - parallel T1's and ML PPP - both work great.
Paul
07-05-2006 03:32 PM
If the existing link is Frame-Relay, AND, if your carrier supports it, check out Multi-Link Frame Relay (MLFR),
The only hardware requirement is enough interfaces for the number of T1/DS1's you want to bundle, and the only software requirement is that the firmware version also supports it.
Good Luck
Scott
07-06-2006 09:45 AM
Thanks for the replies. It looks like I will use multilink ppp. The new T1 won't be installed for a while yet, hopefully gives me some time to find a couple of spare routers to test it out.
Thanks all!
Little_Wing
07-06-2006 09:56 AM
take a look at this:http://www.cisco.com/univercd/cc/td/doc/product/aggr/10000/10ksw/mlppos.htm
rate this post if it helps
regards
Devang
08-29-2006 05:03 AM
I have two T1's similiar to above. I have added MLPPP to routers on both sides and cannot seem to bond.
I have removed one of the T1s so i could remotely connect to far side, and work on adding one t1 to MLPPP but cannot get it to work.
Here is output, any help would be appreciated.
interface Multilink1
ip address x.x.x.x/30
no cdp enable
ppp multilink
no ppp multilink fragmentation
multilink-group 1
interface Serial0/0
no ip address
encapsulation ppp
no ip route-cache
no ip mroute-cache
no fair-queue
service-module t1 fdl ansi
ppp multilink
multilink-group 1
sh int multilink 1
Multilink1 is down, line protocol is down
Hardware is multilink group interface
08-29-2006 01:05 PM
after debugging the issue: debug ppp negotiation, the output suggested i had a AAA authorization issue. Once i saw the problem with this portion of the config, i added
aaa authorization network NOAUTH none
interface Serial1/0:0
ppp authorization NOAUTH
This corrected the issue.
Hope this helps someone in the future.
07-10-2006 07:59 PM
I have an example of load sharing between two T1's that I have setup in the past for an Aggregation of 3MB.
interface Serial0
ip address xxx.xxx.xxx.xx1 255.255.255.252
no ip proxy-arp
ip load-sharing per-packet
no ip mroute-cache
no cdp enable
interface Serial1
ip address xxx.xxx.xxx.xx2 255.255.255.252
no ip proxy-arp
no ip mroute-cache
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xx1
ip route 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xx2
I hope this will help.
Thanks Jim
07-17-2006 08:31 AM
How do you guys verify the aggregated rate is doubled?
07-24-2006 06:34 AM
If you are going to add another T1 later on make sure the second T1 has to come from same vendor and same central office and the seme switc, otherwiese MLPP will not work thanks JM
07-26-2006 11:12 AM
Joe,
MLPP is independent of the carrier. If the T1s are point to point, it should not matter what carrier they are from.
Steve
